ilogic: search and supress element in pattern
mario170979
Message 1 of 1
mario170979
Hello, i need a rule which let me select components in assembly then supress this automaticly.
Up to know i have actual the part to select the elements but get problems to supress this because in 100% of cases the items are in pattern included.
So i think i need a function which search according the item name the element in every pattern insdie the assembly and supress it. importand that i get the element suppressed and not the item that i dont need to add a new level of detail.
Sub Main()
doc = ThisDoc.Document
If doc.DocumentType = kPartDocumentObject Then
oPart("")
Else If doc.DocumentType = kAssemblyDocumentObject Then
SelectPart
End Sub
Sub SelectPart()
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
	comp = ThisApplication.CommandManager.Pick(
		SelectionFilterEnum.kAssemblyOccurrenceFilter,
		"Select a component")
	If IsNothing(comp) Then Exit While
	comps.Add(comp)
End While
For Each comp In comps
oPart(comp.Name)
Next
End Sub
Function oPart(arg)
'here need some help
End Function
MR
Autodesk Inventor Professional 2025
Autodesk Vault Professional 2025
Replies (0)
