iLogic script to write base unit to iproperty
williamRPTGK
williamRPTGK
Hi, I am setting up our templates to work with a new PLM system and as part of this I want to have a custom iproperty that reflects the base unit on the part. I have read through similar forum posts and tried to implement the various solutions but I am now stuck. I currently have the script below:
baseUnit = ThisApplication.ActiveDocument.ComponentDefinition.BOMQuantity.Baseunits
iProperties.Value("Custom", "Base Unit") = baseUnit
This does work but only when a base unit other than "Each" is selected in the document properties. For example, set base unit to mm:
Run script and view iproperties:
And it works as I want. However if I set the document settings back to the default 'each' (which is what it will be 99% of the time):
Then when I run the iLogic rule I just get blank in the iproperty:
Any help appreciated. Please note I am after the base unit (not quantity). Running inventor 2021 with all available updates.
Thanks in advance.
WCrihfield
Hi @williamRPTGK.  The online documentation of the BOMQuantity.BaseUnits property, specifies that is only applies when BaseQuantity is set to a parameter, therefore it does not return anything when that is not the case.  Do you want your iLogic rule to write "Each" to the iProperty when this is the case?  If so, here is a fairly simple modification to your rule that should handle that situation:
Dim baseUnit As String = ThisApplication.ActiveDocument.ComponentDefinition.BOMQuantity.Baseunits
If String.IsNullOrEmpty(baseUnit) Then
	iProperties.Value("Custom", "Base Unit") = "Each"
Else
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
williamRPTGK
Worked perfectly - many thanks.
