iLogic script to show Master view of the assembly
Hi, I`m pretty sure most of the guys had same problem, when open an assembly not all parts are shown. To be able to see entire assymbly need to change View representation to Master manually.
Does anyone know how to achieve this in Ilogic?
Thanks in advance.
jletcher
When you open the assembly 1st goto options and select master before you open it.
yes, thank you. I knew about this option. Would like to have an iLogic code if such exists to perform this operation automatically.
jdkriek
Here's the solution in iLogic as requested 😉
oApp = ThisApplication
If oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
	oAsmCompDef = oApp.ActiveDocument.ComponentDefinition
		For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations
			If oViewRep.Name = "Master"  Then
				oViewRep.Activate
				On Error Resume Next
			Else
		Next
Else
	MsgBox("Assembly Document Is Not Open")
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Awesome! Thanks a lot!!!!
jdkriek
You're quite welcome!
Jonathan D. Kriek
