iLogic SaveAs Error
iLogic SaveAs Error
Daan_M
iLogic SaveAs Error
Daan_M
I'm getting some strange behaviour when saving my configuration with the following code:
oDDoc As DrawingDocument = ThisDrawing.Document
oExcelDoc = "C:\Data\exceltest.xlsm"
oDocName = "TestName"
oMapNumber 	=  GoExcel.CellValue(oExcelDoc, oESheet, "A1")
Dim oDestPath As String = "C:\Data\" & oMapNumber & "\" 'Directory
Dim oDwgFile As String = oDestPath & oDocName &  ".dwg"
Dim oPdfFile As String = oDestPath & oDocName &  ".pdf"
oDDoc.SaveAs(oDwgFile, True)
oDDoc.SaveAs(oPdfFile, True)
I get the following error:
What i find suprising is that it does generate the .dwg correctly, even though it throws an error.
However it does not generate the .pdf?
EDIT: trying to export the drawing as .pdf manually through the Inventor UI also doesn't work.. 'Save as type' field is empty aswell:
JhoelForshav
Hi @Daan_M
It's strange that it can save the dwg and not the pdf. When I tried it I had to make sure the directory exists before running the code for either of them to work:
Dim oDDoc As DrawingDocument = ThisDrawing.Document
If System.IO.Directory.Exists(oDestPath) = False Then
	System.IO.Directory.CreateDirectory(oDestPath, Nothing)
Also make sure the directory doesn't contain any documents with the same names to begin with and maybe clear Inventors memory of unreferenced documents if they have been created before and have just been deleted from the folder:
ThisApplication.Documents.CloseAll(True)
Daan_M
Thanks for the reply, I dug on the forums and found another user that had a similar kind of problem exporting .dwg, it referenced this troubleshooting thread:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Resetting the Utilities fixed it, no code adjustment was needed in the end, i still put in your suggest below tho 😉
