iLogic SaveAndReplace
hkempeneers
hkempeneers
In an assembly we have to Save and Replace all referenced documents.
Very briefly: in Factory Design every inserted asset is getting a very long code in the File Name. We need short names.
And for every asset we need an unique filenumber, codes in FDU are not unique even thought it seems so..
I wrote the following code (every thing works, except the SaveAndReplace at the end) but I get the following error message.
Who knows what to do?
InvDoc = ThisDoc.Document
 Dim oRefDocs As DocumentsEnumerator = InvDoc.AllReferencedDocuments
 Dim oRefDoc As Document
 For Each oRefDoc In oRefDocs
		'Only filenames without $
		Dim oNameCheck As String = oRefDoc.FullDocumentName
		'i = MessageBox.Show(oNameCheck, "document nr", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		If oNameCheck.Contains("$") Then
			'Skip it!
		Else
			Dim oPartNumber As String = oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value
			Dim Time As DateTime = DateTime.Now
			Dim Format As String = "$yyyymmddThhmmss"
			Dim DTG As String = Time.ToString(Format)
			'format model file name
			'For now a fixed path is given
			Dim Folder_Location As String = "C:\VaultWS2\WSP Systems\Factory Assets\"
'			'Assembly
			If oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
				Dim oNewFileName As String = Folder_Location & DTG & "_" & oPartNumber & ".iam"
'				i = MessageBox.Show(oNewFileName, "nieuwe naam assy", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
'			'Part
			ElseIf oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
				Dim oNewFileName As String = Folder_Location & DTG & "_" & oPartNumber & ".ipt"
'				i = MessageBox.Show(oNewFileName, "nieuwe naam prt", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
'		'Save And Replace
	     oRefDoc.Document.SaveAs(oNewFileName, True)
		FileChange = True
Next
 iLogicVb.UpdateWhenDone = True
JhoelForshav
Hi @hkempeneers
Since you dim the variable oNewFileName inside specific if statements it doesn't exist outside them. I moved it so that the object exists all the way. I also removed the big Else portion of the code and wrote the condition to skip documents like this instead:
If oNameCheck.Contains("$") Then Continue For
Finally, since you're traversing the referenced documents, not the assembly occurrences I had to change the SaveAs-line to this:
oRefDoc.SaveAs(oNewFileName, True)
 And added a line to replace the reference in the assembly to the new file:
InvDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc)(1).Replace(oNewFileName, True)
So the complete code looks like this:
	'Skip it!
	'			'Assembly
		oNewFileName = Folder_Location & DTG & "_" & oPartNumber & ".iam"
		'			'Part
		oNewFileName = Folder_Location & DTG & "_" & oPartNumber & ".ipt"
	'		'Save And Replace
	oRefDoc.SaveAs(oNewFileName, True) 'Removed ".Document" here - you already have the document object
	'Replace in assembly
	FileChange = True 'Dont know why you have this line
Next
hkempeneers
@JhoelForshav
It works!
Many thanks, really appreciate
Grtz.
