ilogic Save Copy As image with variable name
Hello!
I have an idea of a new iLogic rule I wanted to create. The purpose of it was to Save Copy As an image file of a model.
For an example if I Save Copy As a ".bmp" file with the name "PIC_1", it would be great to Save Copy As a new ".bmp" file called "PIC_2" .  The purpose of the rule is, that it should understand, that if I have a file with the original name saved, it will save a copy with another name.
The beginning of my code works fine, but somehow I just can't get it to write a new picture file with name.
Can anybody more fluent give me a hand with my struggle pleas?
The beginning of my iLogic rule:
sPath = "C:\files\"
ThisDoc.Document.SaveAs(sPath + "PIC_1" + ".bmp", True)
If ThisDoc.Document.SaveAs(sPath + "PIC_1" + ".bmp", True), Then
 ThisDoc.Document.SaveAs(sPath + "PIC_2" + ".bmp", True)
Curtis_Waguespack
Hi @Anonymous ,
Here's an example.
I hope this helps.
Curtis
sPath = "C:\Temp\PIC_.bmp"
sFirstFile = "C:\Temp\PIC_1.bmp"
If System.io.File.Exists(sFirstFile) Then
    Dim folderPath = System.io.Path.GetDirectoryName(sPath)
    Dim fileName = System.io.Path.GetFileNameWithoutExtension(sPath)
    Dim extension = System.io.Path.GetExtension(sPath)
    Dim fileNumber = 0
    Do
        fileNumber += 1
        sPath = System.io.Path.Combine(folderPath,
                                String.Format("{0}{1}{2}",
                                              fileName,
                                              fileNumber,
                                              extension))
    Loop While System.io.File.Exists(sPath)
Else
	sPath = sFirstFile
ThisDoc.Document.SaveAs(sPath, True)
Thanks! It works just great!
Can you suggest some any website from where I can learn about iLogic macros and maybe get some macro related commands?
With best regards....
Curtis_Waguespack
Hi @Anonymous
The iLogic editor allows you to use VB.Net code to work with Inventor's API (application programming interface) within in it, and even mix Vb.net with iLogic functions, which technically is what the code I posted would be. So with that in mind you can often do a Google search for what you want to do such as "Vb.net + save file and increment name" which is how I found an example to start with:
http://www.vbforums.com/showthread.php?731011-Increment-the-filename-if-file-already-exists-Resolved
To find more information on Inventor's API  you can access the API help from Inventor as shown here:
Autodesk%2BInventor%2BAPI%2BHelp%2BExamples%2B1
I hope this helps.
Curtis
