iLogic Save As PDF Setting Current Document Default Settings
jeremiah_boe
jeremiah_boe
I have read through all of the Save As PDF threads, but everyone is trying to logically complete the Save As PDF process. Is there a way to code the default options, so that a PDM system that automatically generates the PDF's will have the proper settings. The PDM system creates the PDF through the Save As function instead of the print function.
Inventor 2016
chandra.shekar.g
Autodesk Support
Autodesk Support
@jeremiah_boe
Advanced technique in iLogic allows to add thirty dlls as Reference. For more details, refer below article in the following link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-32B66838-22E4-4A0A-B5BB-862350C76B36
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
