iLogic: Save as... PDF options
I am writing some ilogic and would like to set the Save as... PDF (or DXF) options.  This will give me a uniform output.
I can't find where this is stored much less what call to make.
Any ideas?
MjDeck
Do you want to set the options that will be used when you do a Save As Copy operation manually?  I don't think that's possible.
You can have a rule do the export, and set the options for the export in the same rule.
Mike Deck
Software Developer
Autodesk, Inc.
Mike,
Thank you.
Now that i know that i can make API calls, there is one for PDFout, where I can set the options at that time.
So this will be more flexible.
What I need to work on now is how to use use the API to look for specific information within a file (example: the Drawing Base view scale) and set that within iLogic parameter.  This way i can expand some iLogic to populate the Titleblock.
I haven't played around with the API yet, so i am learning as I go.
Thank youin advance for the help.
Jon
