iLogic RunRule arguments for sub components
herrwolf1
herrwolf1
Which of the following options work with the "iLogicVb.RunRule" command?
1. The actual Inventor document object? {Inventor.Document}
2. The document name? {Part1.ipt}
3. The browser display name? {Part1:1}
      A. Is the hierarchy to the component required?
pierre.masson
Hi
Not exactly sure about what you want to do. Vbrunrule is used to call an Ilogic Rule and you need to write the name of the rule.
If this is linked with Occurences, you will find some inspiration here :
http://beinginventive.typepad.com/being-inventive/2010/04/replacing-and-renaming-components-in-an-as...
  iLogicVb.RunRule(occ.Name, "Part number")
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
