iLogic run macro in excel
Hello friends,
Is there a command within iLogic to run an excel macro?
I have an embedded excel workbook which gets passed parameter values via an iLogic rule. I'd like it to then run a macro and read the value of a few cells after the macro has finished.
See below my rule and the point at which I'd like the macro to run.
GoExcel.CellValue("3rd Party:Embedding 1", "Data Input", "B2") = param1
GoExcel.CellValue("B3") = param2
GoExcel.CellValue("B4") = param3
'''''***** RUN MACRO called Front *****''''' posA = GoExcel.CellValue("B20") posB = GoExcel.CellValue("B21") posC = GoExcel.CellValue("B22")
frederic.vandenplas
This code executes the vba code in excel (under module1, create a sub called "Test")
Sub XLTest()
     Dim XL As Object
     Set XL = GetObject(, "Excel.Application")
     XL.Run "Module1.Test"
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
@frederic.vandenplas
I get the following error with your code:
Cannot create ActiveX component.
Using Inv Pro 2015
sorry wrong account
