iLogic rules gets triggered by another rule
Daan_M
Daan_M
I've got two iLogic rules, but one of them seems to trigger the other somehow.
Rule 1 = Assemble
Rule 2 = Check Excel
When i check the Excel, it somehow runs Rule 1 after it's finished, but i don't understand why.
Rule 2 code:
Imports System.Text.RegularExpressions
Imports Microsoft.VisualBasic.FileIO
Sub Main()
Dim oDoc As Inventor.Document = ThisDoc.Document
Dim oSourceFile As String = "X:\Path\Test.xlsx"
Dim CellCounter As Integer = 1
Dim FileTotal As Integer = 4
Do While CellCounter < FileTotal
Parameter("Type") 				= GoExcel.CellValue(oSourceFile, "Blad1", "A" & CellCounter).ToString
Parameter("Vermogen") 			= GoExcel.CellValue(oSourceFile, "Blad1", "B" & CellCounter).ToString
Parameter("Motorflens") 		= GoExcel.CellValue(oSourceFile, "Blad1", "C" & CellCounter).ToString
Parameter("Rem")				= GoExcel.CellValue(oSourceFile, "Blad1", "D" & CellCounter).ToString
Parameter("Handrem")			= GoExcel.CellValue(oSourceFile, "Blad1", "E" & CellCounter).ToString
Parameter("Handrem_Positie") 	= GoExcel.CellValue(oSourceFile, "Blad1", "F" & CellCounter).ToString
Parameter("Wartelpositie")		= GoExcel.CellValue(oSourceFile, "Blad1", "G" & CellCounter).ToString
Parameter("Bestandsnaam")		= GoExcel.CellValue(oSourceFile, "Blad1", "H" & CellCounter).ToString
Parameter("Opslaan") 			= "Ja"
CellCounter = CellCounter + 1
Loop
End Sub
Why is this happening? i disabled all event triggers
Additional information of which i'm not sure wether it's important; The paramater are present in rule 1 as well and get used for the assembly.
Andrii_Humeniuk
Hi @Daan_M . You change user parameters using the Parameter() function, if your Rule 1 = Assemble is among "Event Triggers" "Any User Parameter Change" then it will automatically fire.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Daan_M
Found the problem;
One of the user paramaters in rule 1 was stated as:
Bestandsnaam
instead of:
When rule 2 changes this paramater based on the Excel, the parameterchange triggers rule 1.
Which i still find a bit strange, since i have the Event trigger for 'Any User Parameter Change' disabled;
Either way this solved the problem, for future users looking for the answer
JMGunnar
"Blue"  Parameter always trigger  run rule automatically
this options in rule
Best regards Johan
