iLogic RuleOptions Interface - Fire on Parameter Change
Is there a way to check if the 'Don't run automatically' rule option is True or False?
I can find Enabled and Silent Operation via iLogicAutomation, but can't see an option for 'Don't run automatically'.
Tom
Balaji_Ram
Hi Thomas,
Sorry, I do not think there is way to get that using the automation interface.
The option is available in the "Autodesk.iLogic.Interfaces.iLogicRule" interface as a property named "AutomaticOnParamChange".
But there is no equivalent of it in the "Autodesk.iLogic.Automation.iLogicAutomation" used in iLogic.
It should be possible to know the status of "Don't run automatically" option for a rule using a .Net add-in.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
