iLogic Rule with particular condition not updating the model in factory asset
Lokesh-BAE
Message 1 of 8
Lokesh-BAE
Hello team,
By using Inventor 2021 I'm creating some factory assets.
Created an asset by using the attached assembly model.
In factory layout file, model is not updating properly. Specifically when I enter the "LengthOfTrack" parameter between the 2401 to 2999.
Please refer below code used in iLogic rule "Rule-LengthOfTrack"
ElseIf LengthOfTrack > 2400 And LengthOfTrack < 3000 Then
Parameter("Straight Power And Free Conveyor-PF80 - Chain1:1", "LengthOfTrack") = 1800
Parameter("Straight Power And Free Conveyor-PF80-Chain2:1", "LengthOfTrack") = LengthOfTrack - 1800
Component.IsActive("Straight Power And Free Conveyor-PF80-Chain2:1") = True
Plane_Offset = LengthOfTrack
"Straight Power And Free Conveyor-PF80-Chain2" part length is not updating in assembly.
It would be great help if you can suggest some solution.
Thanks in advance.
Replies (7)
Message 2 of 8
Lokesh-BAE
Hello team,
Please ignore earlier attached files. (My bad..)
And consider the new files attached here for your suggestions.
Message 3 of 8
A.Acheson
Maybe try using Parameter("LengthOfTrack") instead of LengthOfTrack. You are doing some multiplying with the local parameter and it may not update untill the rule is run twice. Can you check the output after each calculation is what you expect?
Regards
Alan
Message 4 of 8
Lokesh-BAE
Using Parameter("LengthOfTrack") instead of LengthOfTrack is not working.
There is no any multiplication in the rule. Only divide and minus math functions are there in the rule. All math functions working perfectly except the one mentioned.
Yes. You are correct. If I run the rule again this function too works. Since I'm using this asset in creation of chain assets, I don't want to open all the files and run the rule again manually.
Please extend your suggestion.
Message 5 of 8
A.Acheson
Ok it sounds like the sub assembly document is not updating. Can you check that value is calculating?
Also try these snippets.
First  at the start of the rule to set parameter updating condition.
'Update parameters controlled by parameter function.
Parameter
.UpdateAfterChange = True
 At end of rule.
'perform some updates on documents and local variables
RuleParametersOutput
() InventorVb.DocumentUpdate()
Regards
Alan
Message 6 of 8
Lokesh-BAE
Thanks for the suggestions.
These suggestions didn't solved the problem.
I found a work around. Which solved my issue.
Wrote a new rule (as below) to rerun the "LengthOfTrack" rule for the condition to which model was not updating.
iLogicVb.RunRule("Rule-LengthOfTrack")
Of course updating the parameter's and document update will help.
Thanks..
Message 7 of 8
A.Acheson
Did you manage to figure out if it is the parameter of the occurrence not updating? I have found that there is a limit to the ilogic access when parameters are too deep / in a sub assembly. The alternate way would be to via the API loop through the occurrences, get occurrence by name then get occurrence definition then parameter and change directly in the document. This article here
and here should have the receipe. Sample below.
' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        If  oOcc.Name = "Name" Then
            Dim param As [Parameter] = oOcc.ComponentDefinition.Parameters.Item("Length")
          MessageBox.Show(param.Value)
    Next
Regards
Alan
Message 8 of 8
Lokesh-BAE
Parameter of the occurrence is updating.
As I don't know anything about API, I didn't tried the method suggested by you.
It might solve the issue.
Thanks again.
