ilogic rule with automatic leader text
eduardolourencoGSSVM
Message 1 of 8
Hello all,
i was wondering if it is possible to have an ilogic rule where i pick an edge or point in a view and it adds a leader text with the following "W1", then i pick another edge and it creates a note with "W2", and so on.
This way i dont need to copy/place a leader text and enter everytime i need to change on each of them.
The final ideia is to have something like this
I lack knowledge of ilogic, so sorry i dont have any code basis to start.
Replies (7)
Message 2 of 8
Michael.Navara
You can implement very complex tool with selection events and preview graphics, but this is not for beginners.
You can use this simple macro which utilizes built-in command for creation of LeaderNotes. You create empty LeaderNotes and when you finish the command, appropriate values will be set automatically. You can run this rule multiple times and the index will continue.
Create LeaderNotes rule
Dim sharedVariableName As String = "W_index"
Dim drw As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = drw.ActiveSheet
Dim leaderNotes As LeaderNotes = sheet.DrawingNotes.LeaderNotes
'Setup index
Dim wIndex As Integer = 1
If SharedVariable.Exists(sharedVariableName) Then
    wIndex = SharedVariable(sharedVariableName)
'Get count of LeaderNotes before start command
Dim countBefore As Integer = leaderNotes.Count
'Start command
'Don't put any text, when you are prompted and
'continue with Ctrl+Enter keyboard shortcut and
'create as many notes as you want
ThisApplication.CommandManager.ControlDefinitions("DrawingLeaderTextCmd").Execute2(True)
'Get count of LeaderNotes after command terminates
Dim countAfter As Integer = leaderNotes.Count
'Set text to currently created LeaderNotes
'previously inserted text will be overwritten
For i As Integer = countBefore + 1 To countAfter
    leaderNotes(i).Text = "W" & wIndex
    wIndex = wIndex + 1
Next
'Store last index for future use
SharedVariable(sharedVariableName) = wIndex
If you want to set new index value, you can use this rule
'Setup index
'Input new value
Dim newIndex = InputBox("Set new index", "W index", wIndex)
wIndex = Integer.Parse(newIndex)
Message 3 of 8
thank you for your help, it works perfectly.
one quick question regarding ilogic coding.
Is there some sort of guide or some kind of "coding tree explanation" (i guess??) to know the commands or access to do stuff?
like for example you have this command
but how can i know that i need to write .CommandManager. ....
there are some snippets that can help but in some rules there is coding that seems like it needs to be from coding experience.
Message 4 of 8
harvey3ELEA
Michael, very nice tool to have.
Is there a simple way for the leader text that I type during creation of each leader note to stay as typed?
Message 5 of 8
Michael.Navara
Inventor API object tree is well described in API reference. There are lot of sample codes and the rest you can find on forums.
Print list of all Inventor Commands API Sample
Break alignment of a section view API Sample
Also you can scroll in dropdown and CommandManager is one line below your screenshot.
Message 6 of 8
Michael.Navara
For text modification is responsible line 27. You can modify the piece of ode as you want. You can keep them unmodified if leaderNotes(i).Text is not empty, add prefix or suffix, etc.
Message 7 of 8
harvey3ELEA
Hi Michael,
Not being much of a coder, I don't know what to do to make my typed text at creation stick regarding line 27 in this group.  If you can offer some advice, I'd certainly appreciate it.  Harvey
    LeaderNotes(i).Text = "W" & wIndex
    wIndex = wIndex + 1
Next
Message 8 of 8
thank you for your reply,
i'll look into it to 🙂
