ilogic rule to set default standard/style for part and assembly
In inventor drawing we would have different standards for part and assembly.
is there an ilogic rule to set default standard for part and assembly?
Curtis_Waguespack
Hi @Anonymous
Here is an example that sets the active drawing standard to a style based on the document type of the model referenced in the first view of the drawing.
I hope this helps.
Curtis
Dim oDoc As Document = ThisDoc.Document
Dim oStylesMan As DrawingStylesManager = oDoc.StylesManager
oMDoc = ThisDrawing.ModelDocument
If oMDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oStylesMan.ActiveStandardStyle = oStylesMan.StandardStyles("Assembly")
ElseIf oMDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oStylesMan.ActiveStandardStyle = oStylesMan.StandardStyles("Part")
