iLogic rule to save a IDW as PDF
part = ThisApplication.Documents.Open(ThisDoc.Path & "\Glashalter mitte.idw", False)
part.SaveAs(ThisDoc.Path & "\Glashalter\Glashalter_mitte_Position" & Position & ".pdf",True)
part.Close()
Hello!
Above is a iLogic rule to save an IDW as PDF (hidden). And it works very good.
But somethings not right whit the layers in PDF when I open it, after starting the rule.
Can you please checkt the files that I attacht in this post???
Alex
Marco.Takx
Hi Alex,
You are said that sometimes you get a wrong layer presentation.
So it's not alway's?
Try it again with this checkbox OFF.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
