ilogic rule to round up to nearest foot
DougJohnston
DougJohnston
Good afternoon all,
I need some help creating a rule, but I am not that experienced with the "MATH" ilogic functions.  So, I would appreciate any help I can get.
I have an assembly that is being driven by a parameter ("door_WIDTH") and I would like to round-up the overall length in (2) stages / increments.
The first increment is to round-up to the next inch:
  eg.  ( 66.625" + 0.375" ) = 67"
Then the second increment is to round-up to the next foot:
   eg.  ( 67" )  to ( 72" )
Can anyone help me out with the code ??
Doug J.
Curtis_Waguespack
Hi @DougJohnston , I think this will do what you're asking.
Hope that helps,
Curtis
' Get the door width parameter
Dim doorWidth As Double = door_WIDTH
roundedToInch = Ceil(doorWidth)
inc = 12
roundedToFootInches = Ceil(Round(doorWidth) / inc) * inc
roundedToFoot = Ceil(Round(doorWidth) / inc)
' Display the results for verification
MessageBox.Show("Original width: " & doorWidth & """" & vbCrLf & _
                "Rounded to inch: " & roundedToInch & """" & vbCrLf & _
                "Rounded to feet in inches : " & roundedToFootInches & """" & vbCrLf & _
                "Rounded to feet: " & roundedToFoot & "'")
DougJohnston
Morning Curtis,
It works the way I wanted ....
Now I need that final (36") to be transferred as a custom parameter I can use in my model (parameter "track_hinged_section_length")
I know it is pretty easy, but I am having a "blonde moment" and can't remember how to convert it to a custom parameter.
Thanks, Doug J.
Curtis_Waguespack
Good morning @DougJohnston,
Here's an update. This version will try to get the parameter and then create it, if it does not exist.
Hope that helps,
Curtis
iLogicVb.UpdateWhenDone = True
inc = 12
' Get the UserParameters collection
Dim UserParams As UserParameters = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
Dim ParameterName As String = "track_hinged_section_length"
Dim trackParam As UserParameter
Try' Try to get the parameter
	trackParam = UserParams.Item(ParameterName)
Catch' Parameter not found, so create it with the correct units
	trackParam = UserParams.AddByValue(ParameterName, 1, UnitsTypeEnum.kInchLengthUnits)
End Try
Parameter(ParameterName) = roundedToFootInches
"Rounded to feet in inches : " & roundedToFootInches & """")
DougJohnston
Thank you very much Curtis
The updated code works perfectly for what I need .... I appreciate all assistance !!
