Ilogic rule to make parts visible in drawing! HLP
I want a rule that makes parts visible in drawing vieuw based on name.
This rule works perfectly in assembly. how can it also work in drawing.
HLP
TNX
DimoDocAsDocument=ThisDoc.Document
DimoCompDefAsInventor.ComponentDefinition=oDoc.ComponentDefinition
DimoCompOccAsInventor.ComponentOccurrence
For
EachoCompOccinoCompDef.OccurrencesvoCompOcc=Component.InventorComponent(oCompOcc.Name)
IfLeft(oCompOcc.Name,2)="55"OrLeft(oCompOcc.Name,2)="51"Then
oCompOcc.Visible=False
EndIf
Next
MegaJerk
It seems as if you might be able to just start using custom View Representations in your actual assembly so that you can create drawing views based on those instead.
Autodesk Inventor Wiki Help : View Reps
Do you feel like you could solve your problem in this way?
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Hello MegaJerk,
In my case I must make the parts visible, because they are behind other parts.
If I can show them on the drawing, and if it's possible to change layers color  to.
All that in one rule.
TNX!
MegaJerk
Could you show us an example of what you're trying to accomplish? Something that you've already done that is the finished product. What your describing just sounds like you could turn hidden lines on to show parts obscured by other parts.
GitHub
Attached You can find the sample!
TNX
