iLogic rule to export PDF's and DWFx for all open documents but want to add DWFx publishes as "complete" not custom or express
Jordan_Kuzma
Message 1 of 1
Jordan_Kuzma
I have an iLogic rule to export PDF's and DWFx for all open documents but want to add to it that the  DWFx publishes as "complete" not custom or express I am new to using iLogic or coding for that matter. Thanks!
Sub Main()
	oInvApp = ThisApplication
	Dim myDate As String = Now().ToString("dd-MM-yyyy")
	myDate = myDate.Replace(":","")  ' & " - " & TypeString
	userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
	UserSelectedActionList = New String(){"DWFX & PDF", "PDF Only", "DWFX Only"}
	UserSelectedAction = InputListBox("What action must be performed with selected views?", _
	UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
	Select UserSelectedAction
	Case "DWFX & PDF": UserSelectedAction = 3
	Case "PDF Only": UserSelectedAction = 1
	Case "DWFX Only": UserSelectedAction = 2
	End Select
	If userChoice Then
		Call MakePDFFromDoc(oInvApp.ActiveDocument, myDate, UserSelectedAction)
	Else
		For Each oDoc In oInvApp.Documents
			If oDoc.DocumentType <> kDrawingDocumentObject Then Continue For
			Try
				If Len(oDoc.File.FullFileName) > 0 Then
					Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
			Catch
			End Try
		Next
 End Sub
 Dim oInvApp As Inventor.Application
 Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
	'oPath = oDocument.Path
	'oFileName = oDocument.FileName(False) 'without extension
	'oDocument = ThisApplication.ActiveDocument
	oPDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = oInvApp.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = oInvApp.TransientObjects.CreateNameValueMap
	oDataMedium = oInvApp.TransientObjects.CreateDataMedium
	oFullFileName = oDocument.File.FullFileName
	oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
	oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
'	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1)
	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) & " " & sDescript
	'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
	'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'oOptions.Value("Custom_Begin_Sheet") = 2
	'oOptions.Value("Custom_End_Sheet") = 4
	' End If
	'get PDF target folder path
	'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	oFolder = oPath & "\Export DWFX & PDF (" & DateString & ")"
	oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName)
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
	'Publish document
	If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
	If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then
		oDocument.SaveAs(oFolder & "\" & oFilePart & ".dwfx", True) 'For DWFX's
	'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".DWFX"), True) 'For DWFX's
	'------end of iLogic-------
 End Sub
Replies (0)
