ilogic rule to drive parts causing issues with other rules
tanguayZKGEL
Message 1 of 20
tanguayZKGEL
I have a very simple assembly with three parts. I have a form set up that can drive the depth, height and length. I then have a rule (that I copied from another user, shown below) that will push those numbers to the other parts and drive their sizes. I also have a number that drives the location of a hole from the left side of the part. This all works awesome and I can enter the numbers and everything updates properly (picture).
There is a pipe coupling beneath the hole. When I add a new rule that drives the model state to turn off the hole and the coupling and then add a multi-value parameter to add the "Yes/No" button to the form, the original rule to push the parameters to the parts has an error (specifically line 55). From my (very limited) understanding/testing, I believe the multi-value parameter is confusing it, as the ilogic doesn't know how to push that to the other parts. I am not sure if there is a way to exclude that parameter or if there is another way of doing what I want. I am quite a novice when it comes to the ilogic stuff... so I am doing a lot of staring and head scratching.
Public Sub Main()
	CopyUserParams()
End Sub
Private Sub CopyUserParams()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
        ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
            ' Add the assembly parameters to the part.
            For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
                ' Check to see if the parameter already exists.
                Dim checkParam As UserParameter = Nothing
                Try
                    checkParam = refDocUserParams.Item(asmUserParam.Name)
                Catch ex As Exception
                    checkParam = Nothing
                End Try
                If checkParam Is Nothing Then
                    ' Create the missing parameter.
                    refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
                Else
                    ' Update the value of the existing parameter.
                    checkParam.Expression = asmUserParam.Expression
            Next
    Next
	iLogicVb.UpdateWhenDone = True
End Sub
Replies (19)
Message 2 of 20
WCrihfield
Hi @tanguayZKGEL.  Have you considered changing the multi-value parameter, which just contains "Yes" & "No" to a Boolean type parameter (True/False).  It seems to me like that would simplify things a bit.  Then instead of a drop-down list containing either the text "Yes" or "No", you could have a simple checkbox there in your form, which would be easier to use, and simpler to copy.
If you need to keep it as a text type, multi-value parameter, then you will need to add more code to your existing code for copying any multi-value parameters it encounters.  The Parameter or UserParameter objects have a property called "ExpressionList", which will return an ExpressionList object, which you can check the Count property of, to see if there is more than one expression for the parameter.  If there is, then you know you need to use a deeper block of code to copy its expressions over too.  You can use the ExpressionList object's ExpressionList.GetExpressionList() method to get 'Array of String' from the source parameter, then access the ExpressionList of the target parameter, and use its ExpressionList.SetExpressionList() method to set that 'Array of String' you got from the source to the target.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 20
CattabianiI
What is your Inventor version?
Message 4 of 20
tanguayZKGEL
@CattabianiI 2022
Message 5 of 20
CattabianiI
This is not the solution, but I'm seeing different behviour between Inv2023.2 (beta version) and Inv2022.3.2. (Which is your installed update version?)
Could you please just add this snippet at line 28 and let me know if it works?
Dim prtCmpDef As PartComponentDefinition = partDoc.ComponentDefinition
If prtCmpDef.IsModelStateMember Then
	partDoc = prtCmpDef.FactoryDocument
Message 6 of 20
tanguayZKGEL
Unfortunately I am met with the same error code pertaining to line 55.
Message 7 of 20
WCrihfield
Here is a slightly modified version of your code, that I have added in both my earlier suggestion, and that of @CattabianiI , and added an extra couple lines in there for possibly using the iLogic shortcut snippet 'MultiValue' to help out, but left those two lines commented out for now.  Take a look at the lines of code I added in there around that point.  If creating the parameter using the AddByExpression method will not work for you, we may have to use the AddByValue method first, then try transferring its Expression later.
Public Sub Main()
	CopyUserParams()
End Sub
		Return
	Dim asmUserParams As UserParameters = asmDoc.ComponentDefinition.Parameters.UserParameters
		If refDoc.DocumentType <> Inventor.DocumentTypeEnum.kPartDocumentObject Then Continue For
		If partDoc.ComponentDefinition.IsModelStateMember Then
			partDoc = partDoc.ComponentDefinition.FactoryDocument
		For Each asmUserParam As UserParameter In asmUserParams
			Try
			End Try
				checkParam = refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
				If asmUserParam.ExpressionList.Count > 1 Then
					Dim oSourceExpressions() As String = asmUserParam.ExpressionList.GetExpressionList
					checkParam.ExpressionList.SetExpressionList(oSourceExpressions)
					'or try using the following 2 lines:
					'sRefFileName = System.IO.Path.GetFileName(refDoc.FullFileName)
					'MultiValue.List(sRefFileName, checkParam.Name) = MultiValue.List(asmUserParam.Name)
			Else
		Next
	Next
End Sub
Wesley Crihfield
Message 8 of 20
CattabianiI
Ok, did I understand well that the part that is giving you error has model state? Could you double check that?
I've just had this idea: is maybe the parameter you're adding in the part already in the part just not as User Parameters?
You can do the check on all parameters (Dim refDocParams As Parameters = partDoc.ComponentDefinition.Parameters) and then do the modification on user parameters like you're already doing.
Other way get back to what @WCrihfield posted before.
Message 9 of 20
tanguayZKGEL
I ran the code as posted with the same error. As stated before, I am still new to ilogic, so looking through the code is a bit overwhelming and not exactly sure what I am looking for...
Message 10 of 20
tanguayZKGEL
That is mostly correct. I have a model state for the part (suppresses the hole) and a model state in the assembly (suppresses the coupling and switches to the model state of the part with the suppressed hole). The parameter with the multi-value is just in the assembly to be able to switch between the assembly model states.
Message 11 of 20
CattabianiI
Try this rule, I added the check if asm parameter is contained in all part's parameters (not just user parameters):
Public Sub Main()
	CopyUserParams()
End Sub
		Return
			Try
				checkParam = refDocParams.Item(asmUserParam.Name)
			End Try
			Else
		Next
	Next
End Sub
Message 12 of 20
tanguayZKGEL
That did not work either. I packed up the files I am working with if that helps...
Message 13 of 20
WCrihfield
I just thought of something else that might be causing a problem right at that line where it is trying to create the new UserParameter by using the AddByExpression method.  What if the 'expression' includes the name of another parameter that does not exist yet within the part, at the time that this UserParameter is being created within the part.  It would not be able to compute a value, and would throw an error.  We might be able to get around that error by using the AddByValue method for creating the parameter, instead of the AddByExpression method.  However, even if we did it that way, then attempted to set its 'Expression' in a later line, it would just throw the error at that point instead.  If this is the scenario that is messing the process up, we might have to somehow delay that one parameter's creation until the end of the process, that way any other parameters that it may be referencing within the part have already been created, or updated.  Just putting my thoughts up on the chalk board for now.
Wesley Crihfield
Message 14 of 20
tanguayZKGEL
Essentially this assembly is used as a starting point to create more like it and inserted into a larger assembly. The design will be copied (most likely in the vault), renamed and then the form will be filled out to modify the part. Trying to automate the process as much as possible and allow for variables to be turned on/off. This assembly is a simpler one with only one option to turn on/off, but would like to apply this method to more complicated assemblies that can have several variables. Trying to learn and get a successful result on something "easier".
Message 15 of 20
WCrihfield
Hi @tanguayZKGEL.  If you just want the parameters within your parts to exactly match the parameters within your main assembly, there is another process you may be able to use, that would not necessarily need to include a bunch of complicated iLogic code.  However, it will only work for numeric parameters, not for text, or boolean (True/False) type user parameters right now...as far as I know.  You could 'link' your part's parameters to the assembly's parameters directly.  This would sort of assume though, that you are not planning on trying to use this same exact part in other similar assemblies, which might complicate things.
To link the parameters you will need to do several things in preparation, after both the part and assembly exist, you have both of them visibly open.
  • With the Assembly visibly open on your screen, open its Parameters dialog, and put a check in the checkbox within the 'Export Parameter' column for each parameter you want to be able to link to the part.  I recommend that you do this mostly with your user parameters, instead of 'Model Parameters', because user parameters are more stable, but it will work either way, if things are set-up correctly.
  • Now with the Part visibly open on your screen, open its Parameters dialog, and click the Link button (lower left of the dialog).
    • An 'Open' file dialog will display, which is prompting you to select a file to link parameters to.
  • In the 'Open' dialog, choose the assembly file, then click the Open button.
    • Then a 'Link Parameters' dialog should pop-up on your screen showing a list of parameters that are available within the assembly, categorized by what type of parameter they are.
    • The ones you marked for Export should have a green arrow by them, indicating their export status.
  • Select those parameters that are marked for export by changing the circular symbol beside them from grey to yellow.  Once all the ones you want are selected this way, click the OK button.
  • Now you should see that those parameters have been created within your part's parameters dialog, within special parameters group containing the path/name of the assembly file.  Those parameters will remain greyed out, except for their 'Key' & 'Export Parameter' check-boxes.  That is because their values can now only be changed by the 'other' document.
Now, any changes you make to those specific parameters within the main assembly, will also change those linked values within the part, but you may have to update the part and/or assembly after changing the values to see the changes.  Similarly, you could also create an Excel file that contains all the 'shared' numerical parameters, then link both the assembly and the parts to that same Excel file, as their source for those parameters, but if you do, you will only be able to edit their values from that Excel file.
Wesley Crihfield
Message 16 of 20
tanguayZKGEL
I like that option and would like to give it a try. I know you said that I cannot link the multi-value/boolean value, which I don't think I will need, but would still like to have in the assembly. Would that screw with the process if I have those parameters still there, but just don't link them?
Message 17 of 20
WCrihfield
No.  Leaving those multi-value or boolean type parameters present within your assembly, and not linking them, should not mess up the linking process.
Wesley Crihfield
Message 18 of 20
tanguayZKGEL
I tried that method, but unfortunately when I try to select the assembly as the link, it states that it was rejected since it causes a cyclic dependency.
Message 19 of 20
WCrihfield
Just checking, but did you delete or rename any parameters that already existed in the part with those same names, before trying to link the assembly's parameters to the part?  What I mean is, if your part already contains a parameter named "LENGTH", and you attempt to link your part to the assembly's parameter, which is also named "LENGTH", it will want to create a new parameter in your part named "LENGTH" (driven by the assembly), but it can't, because there is already a parameter within the part named "LENGTH", and it will not 'use' that existing one that was already in the part.  I honestly have not used a 'link' like this between an assembly and its part(s) myself, even though I have linked parts to each other before, and linked Excel to parts before, so what you are saying might be true, even if your part does not already contain any parameters with the same names.  I have not tried that exact situation before, because I never had the need for it before.
Wesley Crihfield
Message 20 of 20
tanguayZKGEL
I tried both ways. First without changing anything and then by adding a "2" to all the parameters in the assembly.
