ilogic rule to display an ilogic form when creating a new sheet on drawings
Hi there, I couldn't find anything as I need, so that is why I post this...
I'm in the needing of trigger automatically a form I created when a new sheet is created with a specific sheet format I've created...
To be more specific, I have certain data that needs to be displayed as a requirement from my production area in that specific sheet format, so I want that when I create this new sheet by right-clicking the specific Sheet Format and selecting New Sheet, it triggers the show form ilogic rule, to type the data I need to appear in this new sheet that cannot be part of the title block because no other sheets need to display that particular data,
Can anybody throw some light on this?!?!?
Thanks in advance
johnsonshiue
Hi! This might be tricky. I don't think we have sheet or sheet format specific trigger. I guess you will need to trigger the rule when the drawing view is changed. But, in the rule, you check if such condition exists and execute accordingly. Or, it would be a null op.
Many thanks!
Software Test Engineer
