ILOGIC RULE - TO CREATE A FRONT VIEW BELOW THE FLAT PATTERN
formobalaji
Message 1 of 1
formobalaji
I LIKE TO GET THE FRONT VIEW OF ALL THE PARTS IN THE ASSEMBLY BRLOW THE OF ITS FLATPATTERN
Sub Main
	'Check that the active document is an assembly file
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("This rule can only run from an Assembly file", "IDW-creator", MessageBoxButtons.OK, MessageBoxIcon.Error)
		Exit Sub
	'Dim the active document as AssemblyDocument
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Make sure the assembly is saved
	If oDoc.FullFileName = ""
		MessageBox.Show("Please save the Assembly before running this rule.", "IDW-creator", MessageBoxButtons.OK, MessageBoxIcon.Information)
		Exit Sub
	'Get the assembly filename without extension
	Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
	'Get the assembly filepath
	Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
	'Get the parts only BOM.
	Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
	'Make sure Parts Only is activated
	oBOM.PartsOnlyViewEnabled = True
	'Parts only will be last BomView (difficult to get by name since it's different depending on your language)
	Dim oBOMview As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
	'Set a reference to the TransientGeometry object
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	'oX and oY will be used to create points for view placement
	Dim oX As Double = 0
	Dim oY As Double = 0
	'Create the Baseview options to place flatpattern-views
	Dim oBaseViewOptions As NameValueMap
	oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	'Set a variable for the drawing document
	Dim oDrawing As DrawingDocument
	'Create a String to return a message if any SM-parts are not saved
	Dim unsavedSmParts As String = ""
	Dim i As Integer = 1
	Dim oInfo As String = ""
	'Traverse Parts Only BOM
	For Each oRow As BOMRow In oBOMview.BOMRows
		Try
			'Get the component definition for the part
			Dim oDef As ComponentDefinition = oRow.ComponentDefinitions(1)
			'Check if the part is SheetMetal
			If TypeOf (oDef) Is SheetMetalComponentDefinition
				'Set a reference to the partdocument
				Dim smPartDoc As PartDocument = oDef.Document
				'Check if the part is saved
				If smPartDoc.FullFileName = "" Then
					If unsavedSmParts = "" Then unsavedSmParts = "The following SM-documents were not saved and therefore " & _
					"no drawingviews were created:" & vbCrLf
					unsavedSmParts = unsavedSmParts & vbCrLf & oDef.Document.DisplayName
					Continue For
				'Create flatpattern if it doesn't already exist
				If Not oDef.HasFlatPattern
					oDef.Unfold()
					oDef.FlatPattern.ExitEdit()
				'Create the drawing if it doesn't already exist
				If oDrawing Is Nothing
					Dim templatePath As String = "C:\Users\Public\Documents\Autodesk\Inventor 2024\Templates\en-US\Standard.idw"
					oDrawing = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath, False)
					'Set the drawings length units to the same as the assemblys length units
					oDrawing.UnitsOfMeasure.LengthUnits = oDoc.UnitsOfMeasure.LengthUnits
				'Set a reference to the drawing sheet
				Dim oSheet As Sheet = oDrawing.ActiveSheet
				'Create the flatpattern view
				Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(smPartDoc, oTG.CreatePoint2d(oX, oY), 1 _
				, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _
				"FlatPattern", , oBaseViewOptions)
					Dim sPartNumber As String
 					sPartNumber = iProperties.Value("Project", "Part Number")
				oView.Name = smPartDoc.DisplayName
				oView.ShowLabel = True 'If you don`t want to be visible, put False
				'Set the position with our oX and oY
				oView.Position = oTG.CreatePoint2d(oView.Position.X + oView.Width / 2, oView.Position.Y)
				'Move oX to place the next view to the right of this one
				oX = oView.Left + oView.Width + 50
				'Remove the bend lines of the view
				'RemoveBendLines(oView, oDef.FlatPattern)
				'You could comment out this line to keep bend lines
				oInfo = oInfo & If (i = 1, "", vbCrLf) & i & ". " & smPartDoc.PropertySets.Item("Design Tracking Properties"). _
				Item("Part Number").Value
				Dim smPartNumber As String
 					smPartNumber = iProperties.Value("Project", "Part Number")
				i += 1
				'Close the part
				smPartDoc.Close(True)
		Catch Ex As Exception
			MsgBox(Ex.Message)
		End Try
	Next
	   'Save as IDW
    If oDrawing IsNot Nothing
        'Create the save location string for the IDW
        Dim oIDWName As String = oPath & "\" & oAsmName & "_FlatPatterns.idw"
        'Save the IDW
        oDrawing.SaveAs(oIDWName, True)
        MessageBox.Show("IDW saved to: " & oIDWName, "IDW SAVED", MessageBoxButtons.OK, MessageBoxIcon.Information)
        'Create the save location string for the information txt
        Dim oInfoName As String = oPath & "\" & oAsmName & "_FlatPatterns.txt"
        'Create the txt
        CreateTXT(oInfo, oInfoName)
    'Close the drawing
    oDrawing.Close
    'return information about any unsaved parts
    If unsavedSmParts <> "" Then _
    MessageBox.Show(unsavedSmParts, "Some parts were not saved", _
    'Update the assembly (could be dirty if any flatpatterns were created)
    oDoc.Update
End Sub
Sub RemoveBendLines(oView As DrawingView, oFlattPattern As FlatPattern)
    'Get all the bend edges from the FlatPattern
    Dim oBendEdgesUp As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge)
    Dim oBendEdgesDown As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge)
    For Each oEdge As Edge In oBendEdgesUp
        'Get the curves representing these edges in the drawing view
        For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge)
            For Each oSegment As DrawingCurveSegment In oCurve.Segments
                'Set visibility to false
                oSegment.Visible = False
            Next
        Next
    Next
    For Each oEdge As Edge In oBendEdgesDown
            Next
        Next
    Next
End Sub
Sub CreateTXT(oText As String, oFileName As String)
    Dim oTxtWriter As System.IO.StreamWriter = System.IO.File.CreateText(oFileName)
    oTxtWriter.WriteLine(oText)
    oTxtWriter.Close()
End Sub
AND THE LABLE NEED TO SHOW THE FLATPATTERN EXTENDS ,
@WCrihfield
Replies (0)
