ILogic rule to change all units
Message 1 of 14
Hi All
I am after a rule to change the unit type of all .ipts from cm to mm.
This has to go down to all levels in hierarchy  but only change .ipt files
any code would be appreciated
 Dave
Replies (13)
Message 2 of 14
Curtis_W
Hi dclunie,
I think this will work for you (if you modify it a bit):
'get input from user
oUnit = InputRadioBox("Select a units of measure type", "Metric", "Imperial", False, "ilogic")
If oUnit = True then
'set to millimeter
oUOM_1 = UnitsTypeEnum.kMillimeterLengthUnits
'set to kilogram
oUOM_2 = UnitsTypeEnum.kKilogramMassUnits
Else
'set to inch
oUOM_1 = UnitsTypeEnum.kInchLengthUnits
'set to pounds mass
oUOM_2 = UnitsTypeEnum.kLbMassMassUnits
End if
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
	'look at only part files
	 If docFile.DocumentType = kPartDocumentObject Then
	'format  file name
	Dim FNamePos As Long
	FNamePos = InStrRev(docFile.FullFileName, "\", -1)
	Dim docFName As String
	docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
	'set length units
	docFile.unitsofmeasure.LengthUnits = oUOM_1
	'set mass units
	docFile.unitsofmeasure.MassUnits = oUOM_2
	'rebuild to update the display
	docFile.Rebuild
Next
iLogicVb.UpdateWhenDone = True
This is a variation of this rule:
http://inventortrenches.blogspot.com/2012/05/ilogic-rule-to-change-units-of-measure.html
 I hope this helps.
Curtis
Message 3 of 14
Curtis_W
Here's a version specifically, directed toward changing from mm to cm:
oUnit = InputRadioBox("Select a units of measure type", "millimeter", "centimeter", True, "ilogic")
'set to millimeter
Else
'set to centimeter
oUOM_1 = UnitsTypeEnum.kCentimeterLengthUnits
End if
	'format  file name
	'set length units
	docFile.Rebuild
Next
 I hope this helps.
Curtis
Message 4 of 14
scottmoyse
Curtis,
Since the OP didn't say thank you I will. This just saved one of my staff a tonne of time. Thank you very much!
Cheers
Scott.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 5 of 14
toon.gielen
thank you for your post.
I managed to change globally the lbpounds of the parts to kg. The bom was also updated positively.
But I need to add a rule in order this change is permanent. (I use the parts in other projects).
With the rule (under) : it works only once. When I reopen the assembly with all the parts, the unit is again lb pounds.
Specific question. I need to have the kg unit for each part. Permanently stored in the properties of the individual part.
code:
SyntaxEditor Code Snippet
oUnit = InputRadioBox("Select a unit of measure type", "Metric", "Imperial", False, "ilogic")
If oUnit = True Then
'set to millimeter
'set to kilogram
Else
'set to inch
'set to pounds mass
     'set mass units
    docFile.Rebuild
Next
Thank you for helping me.
Message 6 of 14
yan.wangBKEWN
if you want to permanently stored in the properties of the individual part. add this line under the line
docFile.Rebuild
docFile.save
Message 7 of 14
berry.lejeune
@Curtis_W
This code was just what I was looking for. But can this also be done for an individual file? I used the code on an assembly and there it changes all the parts to mm. But I actually need it for an individual part.
Message 8 of 14
berry.lejeune
@Curtis_W
I figured it out already. It was just one line what I needed
ThisApplication.ActiveDocument.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits
Message 9 of 14
Jolanta_Voigt
Observer
Observer
Thank you for all your contributions.
This rule that you shared is very close to what I am looking for.
I need to change units to inch but without user input. I have an excising rule that takes an iAssembly one member at a time, shrinkwraps,save as ipt save as stp save as dwg but somehow Inventor is changing the units from inch to cm when saving as ipt and that ipt being saved as dwg causes the scale to be at 2.54, meaning that if a length is 48 in in the iAssembly the dwg ends up being 48*2.54. So I thought maybe I can insert change units after it saves as ipt and them stp dwg
Our IT man that wrote all those rules for me retired last month 😞
Message 10 of 14
Curtis_W
Hi @Jolanta_Voigt
This example will change all of the documents in an assembly to inches.
I hope this helps.
Curtis
For Each docFile In ThisDoc.Document.AllReferencedDocuments
	docFile.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kInchLengthUnits
Next
Message 11 of 14
Jolanta_Voigt
Observer
Observer
First and foremost I always appreciate your help.
I read more about this on your blog, now I understand better what is happening after reading the section about the internal Inventor units being in cm, that explains my issue why the dwg is scaled to 2.54.
Message 12 of 14
Alexrose1942
For some reason, it doesn't work for me. i want to change all the parameters that i created in mm to cm. did i misunderstand something ?
Message 13 of 14
WCrihfield
Hi @Alexrose1942.  You are talking about changing the units of parameter objects.  This forum thread is talking about changing the 'default' document level units.  The default document level units are set manually within the Document Settings.  The document settings button is located on the Tools tab, Options panel.  Within that dialog, on the Units tab is where these settings are found manually.  That is what they are doing here in this discussion.
If you want a code solution for changing the units of parameters, then it may be better to start a different forum topic for that.  Also, you would need to specify all the details of the task, because code needs to be extremely specific.
  • What document type would be active when the code starts (part, assembly, drawing)?
  • Do you want the code to target only the active document, only target the active document's immediately referenced documents, only target all levels of referenced documents, or the active document and referenced documents?
  • If effecting referenced documents, then what document types do you want it to effect (parts, assemblies, drawings)?
  • Which parameter types should it target (only UserParameters, or ModelParameters and/or other types too)?
And any other useful details that we may need to know.
Edit:  Attached is a text file containing the code for an example iLogic rule you can play around with.  It can be ran on any document type.  It will 'process' that active document, and it will 'process' all levels of that document's referenced documents, without filtering out any specific document type.  The code is modular (multiple routines), with one custom Function routine just for retrieving the Parameters collection from a supplied Document (because it is done differently for models and drawings), and a custom Sub routine just for the primary parameter unit replacement task, designed to process an entire Parameters collection at a time.  That second routine could easily be converted to process a single parameter at a time, instead of an entire collection though.
Wesley Crihfield
(Not an Autodesk Employee)
Message 14 of 14
aniketpunwatkar
Hello worked on it and found the answer to your query,works smoothly and solves your problem:
Dim doc As PartDocument
doc = ThisApplication.ActiveDocument
Dim unitsOfMeasure As UnitsOfMeasure
unitsOfMeasure = doc.UnitsOfMeasure
Dim lengthUnits As UnitsTypeEnum
lengthUnits = UnitsTypeEnum.kMillimeterLengthUnits
unitsOfMeasure.LengthUnits=lengthUnits
You can change the highlighted unit as per your requirement.
