ILogic rule that can change all parts, parameters from the top assembly
Hello again Community.
I'm now in front of a task i cannot handle and I need your help!
My task is to make an ILogic rule that can go into all parts of the assembly (and subassemblies) and change given custom parameters.
The parameters i want to change is called "Kunde" and "Ordrenr".
After the rule is set, I will place it under a form so it will be quick to change.
The closet thing I could find was this..
Dim openDoc As Inventor.Document
Dim docFile As Inventor.Document
Dim DrawingDoc As DrawingDocument
Dim FNamePos As Long
Dim docFName As String
Dim iDesc As String
DrawingDoc = openDoc
openDoc = ThisApplication.ActiveDocument
iDesc = iProperties.Value("Project", "Kunde")
For Each docFile In openDoc.AllReferencedDocuments
'    Check if referenced document is a Part file.  If it is, fill in the SK field.
    If docFile.DocumentType = kPartDocumentObject Then
        'If Not Mid(iDesc, Len(iDesc) - 4, 4) = "<SK>" Then
        '    iDesc = iDesc + "<SK>"
        'End If
        FNamePos = InStrRev(docFile.FullFileName, "\", - 1)
        docFName = Mid(docFile.FullFileName, FNamePos + 1, Len(docFile.FullFileName) - FNamePos)
        iProperties.Value(docFName, "Custom", "SK") = "(SK)"
Next
iLogicVb.UpdateWhenDone = True
With best regards, Mikael Nanke
CCarreiras
Just create the parameter in every part... and link those parameters to the respective parameter in main assembly!!
CCarreiras
Hey Ccarreiras, thank you for responding.
But i'm sad to inform you that this is not a parameter but a Custom property found in Iproterties in every parts and assembly, which is linked to the drawing header, so i cannot force it as an parameter.
CCarreiras
Yes you can , if is a number parameter, you mark the parameter to export...
 if is a text parameter you can't do it directly, but there's other ways...
CCarreiras
Here is the Values i was talking about and they do not show up in the parameter section so i cant export them.
I found the solution!
Also, i have added the most used colors i work with.
With this code,  you will also need a form, with a button connected to a the code called "OrdreKundeFarve", and when the "Kund" and "Ordre Nr" parameter have been set/filled, it can set alle below parts with the same parameters.
SyntaxEditor Code Snippet
'Set Farve
Dim oFarveList As New ArrayList
oFarveList.add("Metal-Steel")
oFarveList.add("1007")
oFarveList.add("1012")
oFarveList.add("1013")
oFarveList.add("1018")
oFarveList.add("1021")
oFarveList.add("2004")
oFarveList.add("3000")
oFarveList.add("3020")
oFarveList.add("5000")
oFarveList.add("5001")
oFarveList.add("5002")
oFarveList.add("5003")
oFarveList.add("5005")
oFarveList.add("5007")
oFarveList.add("5009")
oFarveList.add("5010")
oFarveList.add("5012")
oFarveList.add("5013")
oFarveList.add("5014")
oFarveList.add("5015")
oFarveList.add("5017")
oFarveList.add("5018")
oFarveList.add("5019")
oFarveList.add("5021")
oFarveList.add("5024")
oFarveList.add("6000")
oFarveList.add("6011")
oFarveList.add("6018")
oFarveList.add("6021")
oFarveList.add("6027")
oFarveList.add("6029")
oFarveList.add("6032")
oFarveList.add("7001")
oFarveList.add("7004")
oFarveList.add("7011")
oFarveList.add("7015")
oFarveList.add("7016")
oFarveList.add("7021")
oFarveList.add("7024")
oFarveList.add("7032")
oFarveList.add("7035")
oFarveList.add("7036")
oFarveList.add("7037")
oFarveList.add("7038")
oFarveList.add("7045")
oFarveList.add("8017")
oFarveList.add("9001")
oFarveList.add("9002")
oFarveList.add("9003")
oFarveList.add("9005")
oFarveList.add("9006")
oFarveList.add("9010")
oFarveList.add("9016")
oFarveList.add("9018")
oFarveList.add("9022")
oFarveList.add("U / lak")
oFarveList.add("Galv. EL")
oFarveList.add("Galv. Varm")
oFarveValg = InputListBox("Prompt",oFarveList, oFarveList, Title := "Title", ListName := "List")
iProperties.Value("Custom", "Farve") = oFarveValg
oKundeNummer = iProperties.Value("Custom", "Kunde")
oOdreNummer = iProperties.Value("Custom", "OrdreNr")
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'Check all referenced docs
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
'format file name
    'format file name
    FNamePos = InStrRev(oDoc.FullFileName, "\", -1)
    'returns file name with extension
    docFName = Right(oDoc.FullFileName, Len(oDoc.FullFileName) - FNamePos)
iProperties.Value(docFName,"Custom", "Kunde") = oKundeNummer
iProperties.Value(docFName,"Custom", "OrdreNr") = oOdreNummer
iProperties.Value(docFName,"Custom", "Farve") = oFarveValg
Next
