iLogic rule override another rule
I have two rules in my part, the first is:
If uppersystem <114 Then
Feature.IsActive("Cut12") = False
Feature.IsActive("Flange11")= False
Feature.IsActive("Flange12")= False
Feature.IsActive("Cut9") = False
Feature.IsActive("Flange13")= False
Feature.IsActive("Flange14")= False
ElseIf uppersystem >=114 Then Feature.IsActive("Cut12") = True Feature.IsActive("Flange11")= True Feature.IsActive("Flange12")= True Feature.IsActive("Cut9") = True Feature.IsActive("Flange13")= True Feature.IsActive("Flange14")= True
And my second rule is:
If
hinge = 0 Then
ElseIf hinge = 1 Then
I want the first rule to override (take priority) over the second when the uppersystem < 114 so that all the features suppress. At the moment when uppersystem < 114 my features supress initially but when I change hinge from 0 to 1 or vice versa they appear again.
But it gets even more tricky as when uppersystem >= 114 then I want my second rule to override the first.
Craig
Owner2229
Can't you just use it like this?
If uppersystem < 114 Then
    Feature.IsActive("Flange11") = False
    Feature.IsActive("Flange12") = False
    Feature.IsActive("Flange13") = False
    Feature.IsActive("Flange14") = False
Else
    If hinge = 0 Then
        Feature.IsActive("Flange11") = True
        Feature.IsActive("Flange12") = True
    Else
        Feature.IsActive("Flange13") = True
        Feature.IsActive("Flange14") = True
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Owner2229
I just noticed missing "End If" in the rule. Here it is corrected:
Else
    If hinge = 0 Then
    Else
End If End If
Mike
