iLogic - Rule fails when in a sub-assembly
To iLogic experts out there,
I'm having trouble getting the reference to the assembly using iLogic.
Example
Door.iam - Rule
A rule in the "Door.iam" that uses this command:
Set oAsmDoc = ThisApplication.ActiveDocument
When the Door.iam assembly is opened directly the rule works fine.
House.iam
- Door.iam:1 (sub assembly)
However when "Door.iam" is a sub-component within a parent assembly (eg; House.iam), the rule fails.
Suspected problem
I suspect this is because ThisApplication.ActiveDocument references the parent assembly "House.iam".
How can I make this work in both situations?
Please let me know if you require clarification, I can post an example assembly if necessary.
LukeDavenport
HI BenNeb43,
You want ThisApplication.ActiveEditDocument for that I think.
Hope this helps,
Luke
Thanks Luke!
I think this solves my issue!
Cheers
