ilogic rule fails and crashes
qamar.naseem
qamar.naseem
Unable to cast COM object of type microsoft office error
kelly.young has embedded your image for clarity.
johnsonshiue
Hi! Could you check and see if .Net 4.6 and higher versions are installed? Inventor 2018 requires .Net 4.6 to run properly.
Many thanks!
Software Test Engineer
dgreatice
wrong filename for excel file:
put all pat directory of excel file location, example:
C:\....\test.xls
or
C:\....\test.xlsx
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
qamar.naseem
HI,
Yes all .NET 4.6 and above are already installed
qamar.naseem
Both version types have been tested. Xls & XLSX, but error still ocurrs
qamar.naseem
Yes all NET4.6 & above have been installed
