iLogic Rule Computation Error
DanCintron
Observer Observer
DanCintron
Observer
Observer
I have an iLogic Rule Computation error in an assembly with sub-assemblies.  I cannot publicly post it here, but would be glad to share it privately.  PLEASE help.
WCrihfield
Hi @DanCintron.  Can you at least attempt to describe what the code is doing, and maybe where within that process you believe that the error is happening?  Have you attempted any type of debugging, such as injecting Logger.Info() type lines in various places with information in them about where that line of code is, and what's going on at that point, then checking within the iLogic Log window after the code has ran to see what the entries say, or what the last entry was?
Wesley Crihfield
(Not an Autodesk Employee)
DanCintron
Observer
Observer
Hi @WCrihfield,
Thank you for your response and suggestions.  I appreciate your input.  I haven't attempted detailed debugging yet.  While I have extensive Inventor experience, I'm relatively new to iLogic.  Your guidance would be very much appreciated.
Dan
A.Acheson
Hi @DanCintron
Can you post the rule or a portion of the rule where you think the error happens? If not you can start with the basic debugging assuming  you get the rule to run at all.
Insert a line like below at the start of the rule, if you see the message in the logger window then your rule runs successfully to this point. Next keep moving it down each line of code untill you get the error message and no message in the logger.
Logger.Info("You are here")
 Post to this thread the more info tab of the error message. This is the second tab.
Regards
Alan
