ilogic rule applies to one sheet
J.Oye
J.Oye
I've done this before and I know that there's a snippet for it but......how do I write an ilogic rule where it will only apply to one particular sheet when I have multiple sheets in a drawing?
AdamAG99T
You can get the active sheet with oSheet = ThisDrawing.ActiveSheet, or use the following code to select a single specific sheet number.
oDoc=ThisApplication.ActiveDocument
'assumes a drawing file is active oSheet=oDoc.Sheets(1) 'replace 1 with your desired sheet number
