ilogic rotate and anchor revision table
pschell
pschell
Hello all,
I want to write a rule that rotates the revision table counterclockwise 90 degrees.
I also need the rule to anchor it in place
JaneFan
Hey,
Please try following code:
Dim oSheet = ThisDrawing.Sheet("Sheet:1").Sheet
Dim oRT = oSheet.RevisionTables.Item(1)
Dim oTG = ThisApplication.TransientGeometry
oRT.Position = oTG.CreatePoint2d(10, 10)
oRT.Rotation = 90*PI/180
Jane Fan
Inventor/Fusion QA Engineer
pschell
@JaneFan,
Thank you for your reply.
your rule didn't do as i would have hoped but it did inspire me to write this and this does work!
SyntaxEditor Code Snippet
Sub Main CreateRevTable()
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oRTBs As RevisionTables = oDrawDoc.ActiveSheet.RevisionTables
	' Create the revision table location points
	Dim oLocation As Point2d
	oLocation = ThisApplication.TransientGeometry.CreatePoint2d(55.77, 54.61)
	'add a new table
	Dim oRTB As RevisionTable
	oRTB = oRTBs.Add2(oLocation, True, True, True, "A")
	'Rotate Revision Table
	oRTBs.Item(1).Rotation = 90 * Math.PI / 180
	iLogicVb.UpdateWhenDone = True
End Sub
@pschell or @JaneFan
Do you have any ideas on how to create a rule that will 'pull' my template revision, border, and title block from my computer and insert (or replace depending) to the current drawing?
I am very inexperienced with iLogic, and have only worked with inventor on and off starting this year, any help would be appreciated.
Thanks in advance
