iLogic Regenerate all Rules With Update Button
Jose_Merino
Jose_Merino
I have an assembly, with some rules, involve level of details, so, when I made changes in the master for see all my assembly change accordingly, it change, but I have to click on the button "Regenerate all Rules" to made all the changes, is there a way to avoid this step, an only clicking the update button, all my assembly change
Thank You.
kelly.young has edited your subject line for clarity: Rules Update
Thomas_Savage
At the end of all your rules you can place : InventorVb.DocumentUpdate ()
Which will update. Place that code at the end of all your rules and see how that works.
Hope this helps?
If not I can show you another way to do it.
Thomas
Thomas Savage
Design Engineer
Jose_Merino
It works ok, whit the simple rules, But I have one rule that need to turn Off one inlet, or the other, and in that one is when I need to click the "Regenerate All Rules" button, do yo know how can I make it work, just clicking update.
b_sharanraj
Hi @Jose_Merino
The below Code Re-Generates all the iLogic Codes in Assembly, Sub Assembly & Part Components 🙂
Dim controlDef as ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
controlDef.Execute2(True)
Regards
B.Sharan Raj
