Ilogic Read values from Excel & update assembly component occurrences
mcloughlin_b
Message 1 of 8
mcloughlin_b
Hi Boffins
I am trying to achieve the following from within an Assembly
  1. For each component occurrence in the assembly (top level assembly, subassemblies, parts) lookup a value in an external excel file (Part Number) that matches the inventor part number
  2. populate custom properties for the active occurrence which are found in the corresponding excel row
My first stumbling block is an ilogic error message:"Error in rule program format: The rule must contain: Sub Main() ... End Sub" but my code does have these present. I'm sure this is totally simple but I just can't see where the problem lies. Code is below, pieced together with much hair pulling
SyntaxEditor Code Snippet
Sub Main()
'Create variables'set a reference to the assembly component definintion
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim ExcelFullName, FileName As String
'Set Excel database
ExcelFullName = ThisDoc.Path & "\" & "Import Files" & "\" & "DB_IMPORT.xlsx"
'Open Excel database
GoExcel.Open(ExcelFullName,"Sheet1")
'Iterate through all of the occurrences
Dim oOcc As ComponentOccurrence
    For Each oOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
    Try
        'Extract FileName of active occurrence
           Words = oOcc.FullFileName.Split("\")
        FileName = Words(UBound(Words))
        'Define Custom property set
        Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
        i = GoExcel.FindRow(ExcelFullName, "Sheet1", "Part number", "=", FileName")
        iProperties.Value("Summary", "Comments") = GoExcel.CurrentRowValue("Comments")
        GetProperty(oPropSet, "SYBIZ PART No").Value = GoExcel.CurrentRowValue("SYBIZ PART No")
        GetProperty(oPropSet, "SUPPLYNO").Value = GoExcel.CurrentRowValue("SUPPLYNO")
        GetProperty(oPropSet, "SUPPLYTYPE").Value = GoExcel.CurrentRowValue("SUPPLYTYPE")
        GetProperty(oPropSet, "PBLAST").Value = GoExcel.CurrentRowValue("PBLAST")
        GetProperty(oPropSet, "PPRIME").Value = GoExcel.CurrentRowValue("PPRIME")
        GetProperty(oPropSet, "PTOPCOAT").Value = GoExcel.CurrentRowValue("PTOPCOAT")
        GetProperty(oPropSet, "PMACHINE").Value = GoExcel.CurrentRowValue("PMACHINE")
        GetProperty(oPropSet, "PWELD").Value = GoExcel.CurrentRowValue("PWELD")
        GetProperty(oPropSet, "PBEND").Value = GoExcel.CurrentRowValue("PBEND")
        GetProperty(oPropSet, "PINSTALL").Value = GoExcel.CurrentRowValue("PINSTALL")
        GetProperty(oPropSet, "PASSEMBLE").Value = GoExcel.CurrentRowValue("PASSEMBLE")
        iLogicVb.UpdateWhenDone = True
    End Try
    Next
'Close Excel database
GoExcel.Close
End Sub
Function GetProperty(oPropset As PropertySet, iProName As String) As Inventor.Property
    ErHa = "GetProperty: " & iProName
    Dim iPro As Inventor.Property
    Try
        'Attempt to get the iProperty from the document
        iPro = oPropSet.Item(iProName)
    Catch
        'Assume error means not found, so create it
        iPro = oPropSet.Add("", iProName)
    End Try
    Return iPro
End Function
 Can anyone please help?
Cheers
Bryan
Replies (7)
Message 2 of 8
You need to go through the occurrence document definition to get to the property set and full filename.
Give this a try and let me know how you get on:
Sub Main ()
oAsmCompDef = oAssDoc.ComponentDefinition
Dim ExcelFullName As String
Dim FileName As String
'Set Excel database
'Iterate through all Of the occurrences
   ' Try
        Words = oOcc.Definition.Document.FullFileName.Split("\")
        Dim oPropSet As PropertySet = oOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties")
        i = GoExcel.FindRow(ExcelFullName, "Sheet1", "Part number", "=", FileName)
        'iProperties.Value("Summary", "Comments") = GoExcel.CurrentRowValue("Comments")
    'Catch
   ' End Try
    Next
GoExcel.Close
End Sub
    Try
    Catch
    End Try
    Return iPro
End Function
I commented out the 'Comments' iProp because I wan't sure if it was the active document or occurrence document you were looking to write to.
Message 3 of 8
mcloughlin_b
HI Craig
Thanks for your reply. I ended up recreating the code, which at least now runs but with some problems as follows:
  1. I am getting the error message: Conversion from string to type double is not valid and no iproperties are being updated
I have tried to skip excel cells which have no value or null value by using the following
If GoExcel.CurrentRowValue("SYBIZ PART No") = ""
        Else If GoExcel.CurrentRowValue("SYBIZ PART No") = 0 Then
but I'm totally unsure if this has any effect. My revised code is below if you are willing to have a look for me. Many thanks as I am about to start screaming...
Sub Main ()
Dim oAssDoc As AssemblyDocument = ThisApplication.ActiveDocument
'Set Excel database
'Iterate through each referenced document'Dim oOcc As ComponentOccurrence
    For Each oDoc As Document In oAssDoc.AllReferencedDocuments
    ERHA = "Start"
    Try
        'Extract Part Number of active occurrence
        oSC = oPropSet.Item("SUBCAT")
        oPN = oPropSet.Item("PART NO")
        oPartNumber = oSC.Value & "-" & oPN.Value
'        MessageBox.Show(oPartNumber, "Title")
    ErHa = "Define custom property collection"
        Parameter.UpdateAfterChange = True
        i = GoExcel.FindRow(ExcelFullName, "Sheet1", "Part Number", "=", oPartNumber)
        If GoExcel.CurrentRowValue("SYBIZ PART No") <> "" Then
        If GoExcel.CurrentRowValue("SUPPLYNO") = ""
        Else If GoExcel.CurrentRowValue("SUPPLYNO") = 0 Then
        If GoExcel.CurrentRowValue("SUPPLYNO") <> "" Then
        Else
        If GoExcel.CurrentRowValue("SUPPLYTYPE") = ""
        Else If GoExcel.CurrentRowValue("SUPPLYTYPE") = 0 Then
        If GoExcel.CurrentRowValue("SUPPLYTYPE") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PBLAST") = ""
        Else If GoExcel.CurrentRowValue("PBLAST") = 0 Then
        If GoExcel.CurrentRowValue("PBLAST") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PPRIME") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PTOPCOAT") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PMACHINE") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PWELD") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PBEND") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PINSTALL") <> "" Then
        Else
        If GoExcel.CurrentRowValue("PASSEMBLE") <> "" Then
        Else
'        If GoExcel.CurrentRowValue("NOTES") <> "" Then
        GetProperty(oPropSet, "NOTES").Value = GoExcel.CurrentRowValue("NOTES")
'        Else'        End If'    Catch
    ErHa = "Update the file"
        Catch ex As Exception
        MsgBox("Part: " & oDoc.DisplayName & vbLf & "Code-Part: " & ErHa & vbLf & "Error: " & ex.Message)
    'Catch
    End Try
    Next
GoExcel.Close
End Sub
Private ErHa As String = vbNullString
    Try
    Catch
    End Try
    Return iPro
End Function
 Cheers
Message 4 of 8
This works perfectly for me. Can you try it and let me know if it does for you also. If you receive any errors please post them also.
Sub Main ()
'Set Excel database
    ErHa = "Start"
    Try
        'MessageBox.Show(oPartNumber, "Title")
    End Try
    Next
GoExcel.Close
End Sub
    Try
    Catch
    End Try
    Return iPro
End Function
Message 5 of 8
Hi @mcloughlin_b
Sorry was in a rush yesterday and I never properly read through the issue you were having.
The following code should handle any blank excel values it come across. It will set the corresponding iProperty to a blank string (""), although you can change this to whatever you need it to do.
P.S I only did a few properties to test the code and commented the rest out, but you get the gist of it Smiley Wink
Sub Main ()
'Set Excel database
    ErHa = "Start"
    Try
        Dim SYBIZ_PART_No As String = GoExcel.CurrentRowValue("SYBIZ PART No")
        If String.IsNullOrEmpty(SYBIZ_PART_No) Then
        GetProperty(oPropSet, "SYBIZ PART No").Value = ""
        Else
        GetProperty(oPropSet, "SYBIZ PART No").Value = SYBIZ_PART_No
        Dim SUPPLYNO As String = GoExcel.CurrentRowValue("SUPPLYNO")
        If String.IsNullOrEmpty(SUPPLYNO) Then
        GetProperty(oPropSet, "SUPPLYNO").Value = ""
        Else
        GetProperty(oPropSet, "SUPPLYNO").Value = SUPPLYNO
        Dim SUPPLYTYPE As String = GoExcel.CurrentRowValue("SUPPLYTYPE")
        If String.IsNullOrEmpty(SUPPLYTYPE) Then
        GetProperty(oPropSet, "SUPPLYTYPE").Value = ""
        Else
        GetProperty(oPropSet, "SUPPLYTYPE").Value = SUPPLYTYPE
        Dim PBLAST As String = GoExcel.CurrentRowValue("PBLAST")
        If String.IsNullOrEmpty(PBLAST) Then
        GetProperty(oPropSet, "PBLAST").Value = ""
        Else
        GetProperty(oPropSet, "PBLAST").Value = PBLAST
'        GetProperty(oPropSet, "PPRIME").Value = GoExcel.CurrentRowValue("PPRIME")
'        GetProperty(oPropSet, "PTOPCOAT").Value = GoExcel.CurrentRowValue("PTOPCOAT")
'        GetProperty(oPropSet, "PMACHINE").Value = GoExcel.CurrentRowValue("PMACHINE")
'        GetProperty(oPropSet, "PWELD").Value = GoExcel.CurrentRowValue("PWELD")
'        GetProperty(oPropSet, "PBEND").Value = GoExcel.CurrentRowValue("PBEND")
'        GetProperty(oPropSet, "PINSTALL").Value = GoExcel.CurrentRowValue("PINSTALL")
'        GetProperty(oPropSet, "PASSEMBLE").Value = GoExcel.CurrentRowValue("PASSEMBLE")
'        GetProperty(oPropSet, "NOTES").Value = GoExcel.CurrentRowValue("NOTES")
    End Try
    Next
GoExcel.Close
End Sub
    Try
    Catch
    End Try
    Return iPro
End Function
Message 6 of 8
mcloughlin_b
Hi Craig
That did the trick, working perfectly so far. I'll run some tests on a few assemblies with excel import containing both text and number strings to check.
Many thanks for your input.
Bryan
Message 7 of 8
heesu_kimHMK7G
Hello.
I also wanted to use that content, so I modified the code as follows.
However, when running, an error message such as the image below appears.
May I know what the problem is??
Sub Main()
    'Create variables and set a reference to the assembly component definition
    Dim oStockNo As String
    Dim oStatus As String
    Dim oProject As String
    Dim oPartNumber As String
    Dim Parameter As Object ' Define Parameter object
    Dim i As Integer
    Dim iLogicVb As Object ' Define iLogicVb object
    'Set Excel database
    ExcelFullName = "C:\Users\heesu.kim\Desktop\고객사\에이유테크\bomlist.xlsx"
    ' Open Excel database
    Dim GoExcel As Object ' Define GoExcel object
    GoExcel = CreateObject("Excel.Application")
    GoExcel.Workbooks.Open(ExcelFullName)
        Dim ErHa As String ' Move ErHa declaration inside the loop
        ErHa = "Start"
        Try
            oPropSet = oDoc.PropertySets.Item("Inventor User Defined Properties")
            oStockNo = oPropSet.Item("스톡 번호").Value
            oStatus = oPropSet.Item("상태").Value
            oProject = oPropSet.Item("PROJECT").Value
            oPartNumber = oStockNo & "-" & oStatus & "-" & oProject
            'Define custom property collection
            i = GoExcel.FindRow(ExcelFullName, "BOM", "PROJECT", "=", oPartNumber)
            SYBIZ_PART_No = GoExcel.CurrentRowValue("SYBIZ PART No")
            Else
            SUPPLYNO = GoExcel.CurrentRowValue("SUPPLYNO")
            Else
            SUPPLYTYPE = GoExcel.CurrentRowValue("SUPPLYTYPE")
            Else
            PBLAST = GoExcel.CurrentRowValue("PBLAST")
            Else
        End Try
    Next
    GoExcel.Quit()
    ReleaseObject(GoExcel) ' Release Excel object
End Sub
Private Function GetProperty(oPropset As PropertySet, iProName As String) As Inventor.Property
    Try
        iPro = oPropset.Item(iProName)
    Catch
        iPro = oPropset.Add("", iProName)
    End Try
    Return iPro
End Function
Private Sub ReleaseObject(ByVal obj As Object)
    Try
        If Not obj Is Nothing Then
            System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
            obj = Nothing
        obj = Nothing
    Finally
        GC.Collect()
    End Try
End Sub
Thank you.
Message 8 of 8
A.Acheson
Hi @heesu_kimHMK7G
Your error is occuring in this block and finding the error will involve stepping through each line within the try catch statement with either a message box or logger statement. If the message appears the line of code is good. When you receive the error message again then you have reached the error line.
It might be as simple as checking the document is modifiable before you begin trying to process the document. Something like this will avoid trying to modify content center or library parts.
Syntax
Document.IsModifiable() As Boolean
and to use in a for loop
If oDoc.IsModifiable = False Then Continue For
Error in this section.
Try
            Else
            Else
            Else
            Else
        End Try
Regards
Alan
