Ilogic read csv file in as variables
I am reading in a 2 line csv file. The first line contains strings representing variables and the second line, the values.
my question is, how do you read these in creating iLogic variables of each pair?
ie csv contains:
length. Width
1000.     500
i want ilogic variables of length and width created with the relevant values.
many thanks in advance
Dave
JelteDeJong
you could try the following:
Dim splitChar As String = ","
Dim keyLine As String
Dim valLine As String
Using reader As New IO.StreamReader("c:\temp\test.csv", Text.Encoding.Default)
    keyLine = reader.ReadLine()
    valLine = reader.ReadLine()
End Using
Dim keys As String() = keyLine.Split(splitChar)
Dim vals As String() = valLine.Split(splitChar)
Dim csvData As Dictionary(Of String, String) = New Dictionary(Of String, String)()
For i = 0 To keys.Count - 1
    csvData.Add(keys(i), vals(i))
Next
For Each item As KeyValuePair(Of String, String) In csvData
    MsgBox(item.Key & ": " & item.Value)
Next
This will fail if the number of key and values are not the same. If you have control over how the csv file is made i would advice you to setup different. its better tou put a key/value pair on each line. like this:
length,1000
Width,500
Its more easy to read and the following iLogic rule will not fail enterly when a line is not correct.
            Dim line As String = reader.ReadLine
            Do While (Not line Is Nothing)
                Try
                    Dim splittedLine As String() = line.Split(splitChar)
                    csvData.Add(splittedLine(0), splittedLine(1))
                Catch ex As Exception
                    MsgBox("Could not add data from line: " & line)
                End Try
                line = reader.ReadLine
            Loop
        End Using
        Next
Jelte de Jong
Blog: hjalte.nl - github.com
stijnkimpe
Observer
Observer
@JelteDeJong
Thanks for this usefull code!
Is it also possible to create an InputListBox  with an array of values read from a CSV file?
I want to fill in 2 custom Props; material and number by select the correct material from an inputListbox.
my csv file looks like this:
Number, Material
1000, Steel
2000, Wood
I know this is possible with an XLS file, but this has a slower read performance because ilogic has to start Excel in the background.
j_weber
Hallo,
by searching for a way to read values from a csv to create Inventor parameters I found this posting.
I have a csv file that contains the parameter names and the values.
I try the second code from @JelteDeJong
A Messegebox show me the pairs but not parameters are created.
What do I wrong or is it not possible to create Inventor Parameter from a csv-file
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
JelteDeJong
That rule was only to show how you can read csv files not to set them as parameters. The following rule will read the csv and also set the parameters.
Sub Main()
    Dim doc As PartDocument = ThisDoc.Document
    Dim userParameters As UserParameters = doc.
        ComponentDefinition.Parameters.UserParameters
    Dim csvData As Dictionary(Of String, String) = ReadCSV("c:\temp\test.csv")
        SetParameter(userParameters, item.Key, item.Value)
    Next
End Sub
Public Function ReadCSV(fileName As String)
            Try
            End Try
        Loop
    End Using
    Return csvData
End Function
Public Sub SetParameter(userParameters As UserParameters, name As String, expresion As String)
    Dim foundPara As UserParameter = userParameters.Cast(Of UserParameter).
        Where(Function(p)
                  Return p.Name.Equals(name)
              End Function).FirstOrDefault()
    If (foundPara Is Nothing) Then
        userParameters.AddByExpression(name, expresion, "mm")
    Else
        foundPara.Expression = expresion
End Sub
Jelte de Jong
j_weber
Thanks @JelteDeJong for your answer and the code
I try it as fast as I can.
by
Jörg Weber
j_weber
Hallo @JelteDeJong
it works great for me. Thanks a lot for help
Jörg Weber
