iLogic – Question About Multiple User Inputs
I wrote iLogic code for a part file that takes user input and calculates cross-sectional area, moment of inertia values (Ix and Iy), and calculates the weight per foot.
My question is about the user input. Currently, my code allows the user to select only one surface to calculate the area, moments of inertia, and weight. Is there a way in iLogic to allow the user to select multiple surfaces? And is there a way to ask the user up front if they want to select one or more than one surface?
I've posted my code below. It's somewhat long, but I wanted to give an idea of what my code currently looks like.
Thanks.
My Code:
'Preliminary Setup
App = ThisApplication
doc = ThisDoc.Document
oCD = doc.ComponentDefinition
oBodies = oCD.SurfaceBodies
oCommandMgr = App.CommandManager
Dim oFace As Face
'1: Check for Bodies
If oBodies.Count = 0 Then
MessageBox.Show("Part File Must Contain a Body!", "iLogic Error Alert:", MessageBoxButtons.OK)
Exit Sub
'2: Check for Planar Faces
blnPlanarFaceCheck = False
For Each oSurfaceBody As SurfaceBody In oBodies
For Each oFace In oSurfaceBody.Faces
If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
blnPlanarFaceCheck = True
GoTo jmpFaceCheck
Next
Next
jmpFaceCheck : If blnPlanarFaceCheck = False Then
MessageBox.Show("There Must Be a Flat Face for Selection!", "iLogic Error Alert:", MessageBoxButtons.OK)
Exit Sub
'3: Check To See If Sketch Is Defined In XY Plane
Dim oSketch As PlanarSketch
oSketch = ThisDoc.Document.ComponentDefinition.Sketches.Item(1)
If oSketch.PlanarEntity.Name <> "XY Plane" Then
MessageBox.Show("The Sketch Must Be Defined on the XY Plane!", "iLogic Error Alert:", MessageBoxButtons.OK)
Exit Sub
'4: Check To See If Material Is Specified
If ThisDoc.Document.ComponentDefinition.Material.Name = "Generic" Then
MessageBox.Show("The Part Has No Material Assigned!", "iLogic Error Alert:", MessageBoxButtons.OK)
Exit Sub
'5: Select Face and Check
jmpFaceSelection : oFace = oCommandMgr.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select planar face to calculate area, Ix, and Iy properties")
If oFace.Type <> ObjectTypeEnum.kFaceObject Then
MessageBox.Show("A Surface Face Must Be Selected!", "iLogic Error Alert:", MessageBoxButtons.OK)
GoTo jmpFaceSelection
'Calculate Area, Ix, and Iy
oTransaction = App.TransactionManager.StartTransaction(doc, "Inertia Calculation")
App.ScreenUpdating = False
oSK = oCD.Sketches.Add(oFace)
oSK.Edit
oCommandMgr.ControlDefinitions("SketchProjectCutEdgesCmd").Execute
oProfile = oSK.Profiles.AddForSolid
oRegProps = oProfile.RegionProperties
dArea = oRegProps.Area
Dim adPrincipalMoments(2) As Double
oRegProps.PrincipalMomentsofInertia(adPrincipalMoments(0), adPrincipalMoments(1), adPrincipalMoments(2))
oSK.ExitEdit
App.ScreenUpdating = True
oTransaction.Abort
'Copy Values to Custom iProperties
iProperties.Value("Custom", "Area") = Format(dArea / 6.452, ".000") 'dividing by 6.452 converts from cm^2 to in^2
iProperties.Value("Custom", "Ix") = Format(adPrincipalMoments(0) / 41.623, ".000") 'dividing by 41.623 converts from cm^4 to in^4
iProperties.Value("Custom", "Iy") = Format(adPrincipalMoments(1) / 41.623, ".000") 'dividing by 41.623 converts from cm^4 to in^4
iProperties.Value("Custom", "Mass") = Format(iProperties.Mass, ".000")
'Additional Custom iProperties
iProperties.Value("Custom", "Material") = Format(iProperties.Material)
iProperties.Value("Custom", "Drawn By") = Format(UCase(iProperties.Value("Summary","Author")))
'6: Check Length of Part
If Round(iProperties.Volume / (dArea/6.452)) <> 12 Then 'dividing by 6.452 converts from cm^2 to in^2
MessageBox.Show("The Part Has Not Been Extruded To a Depth Of 12 Inches!", "iLogic Error Alert:", MessageBoxButtons.OK)
Exit Sub
'If There Are No Errors, Message Box Appears. Runs Through All Previous Checks Before Displaying Message Box.
If oBodies.Count = 1 And '1
blnPlanarFaceCheck = True And '2
oSketch.PlanarEntity.Name = "XY Plane" And '3
ThisDoc.Document.ComponentDefinition.Material.Name <> "Generic" And '4
oFace.Type = ObjectTypeEnum.kFaceObject And '5
Round(iProperties.Volume / (dArea/6.452)) = 12 Then '6
MessageBox.Show("Calculations Made. No Errors Found.", "iLogic Message", MessageBoxButtons.OK)
Exit Sub
'Update the Document That the Rule Is Running In
InventorVb.DocumentUpdate
Yijiang.Cai
You could use "SelectEvent" to trigger the select event, and support the multiple selection. You could access API help document to get the sample code.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
