iLogic push all assembly user parameters to parts
Jelvin_
Message 1 of 27
Jelvin_
Hi
I'm trying to push my assembly user parameters to the assembly parts. I have all my assembly user parameters added to a list called UserParamList(j)
i would like to achieve this
Parameter(FileName, "Length") = Length
With this
Parameter(FileName, UserParamList(j)) = UserParamList(j)
But i notice that UserParamList(j) to the right is expecting a parameter and not a string.
Im using this to collect all my user parameters and stor in my arraylist
For Each oParam In userParams
	If oParam.Units <> "Text" And oParam.Units <> "Boolean" Then
		UserParamList.Add(oParam.Name)
Next
What is the best way to solve this issue? If i just type the parameter name in the ilogic code, it turns blue. I would like my UserParamList(j) to "mimic" this behaviour.
/J
Replies (26)
Message 21 of 27
myronHBBUW
I want to try it from a different direction.
I want to just select one part in the same folder.
From that part i derive my other parts and link my (sub)assemblys.
Can you help me tweak your code to push the properties to below part?
many thanks
docFName = ThisDoc.PathAndFileName(False).Replace( 100 ,"stuurschets")& ".ipt"
Message 22 of 27
myronHBBUW
@Ralf_Krieg , can you help me change your code to push the properties to a single part by full filename?
Message 23 of 27
Ralf_Krieg
Hello
Sorry, I'm currently not here every day.
I assume the source file is not always the same? I added a file open dialog to select the part file to use as source. The version with a hard coded source file is included, but commented.
I'm not able to test it, so please be careful and test it with a test assembly or copy first.
Public Sub Main()
	CopyUserParams()
End Sub
Private Sub CopyUserParams()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
	'Variant A - hard coded SourceFile
	'Dim oSourceDoc As PartDocument = ThisApplication.Documents.Open(ThisDoc.PathAndFileName(False).Replace( 100 ,"stuurschets")& ".ipt", False)
	'Variant B - Select SourceFile in a dialog
	Dim oDlg As Inventor.FileDialog
	ThisApplication.CreateFileDialog(oDlg)
	oDlg.CancelError=False
	oDlg.DialogTitle = "Select parameter source file..."
	oDlg.Filter="Inventor Part Files (*.ipt)|*.ipt"
	oDlg.InitialDirectory=ThisDoc.Path
	oDlg.MultiSelectEnabled = False
	oDlg.OptionsEnabled = False
	oDlg.ShowOpen
    If oDlg.FileName <> "" Then
		MsgBox("File " & oDlg.FileName & " was selected.")
		oSourceDoc = ThisApplication.Documents.Open(oDlg.FileName, False)
	Else
		Exit Sub
	'End of Variant B
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
        ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters
			Try
				refDocUserParams = partDoc.ComponentDefinition.FactoryDocument.componentdefinition.Parameters.UserParameters
			Catch ex As Exception
				refDocUserParams = partDoc.ComponentDefinition.Parameters.UserParameters
			End Try
			Try
	            ' Add the part parameters of source file to the part.
	            For Each sourceUserParam As UserParameter In oSourceDoc.ComponentDefinition.Parameters.UserParameters
	                ' Check to see if the parameter already exists.
	                Dim checkParam As UserParameter = Nothing
	                Try
	                    checkParam = refDocUserParams.Item(sourceUserParam.Name)
	                    checkParam = Nothing
	                End Try
					Dim svalue As String
	            	Dim bvalue As Boolean
	                If checkParam Is Nothing Then
	                   ' Create the missing parameter.
		                If sourceUserParam.Units = "Text" Then
		                    svalue = Replace(sourceUserParam.Value, Chr(34), "")
		                    Call refDocUserParams.AddByValue(sourceUserParam.Name, svalue, sourceUserParam.Units)
		                ElseIf sourceUserParam.Units = "Boolean" Then
		                    bvalue = Replace(sourceUserParam.Value, Chr(34), "")
		                    Call refDocUserParams.AddByValue(sourceUserParam.Name, CBool(bvalue), sourceUserParam.Units)
		                Else
		                    Call refDocUserParams.AddByExpression(sourceUserParam.Name, sourceUserParam.Expression.ToString , sourceUserParam.Units)
		            Else
		                ' Update the value of the existing parameter.
		                    checkParam.Value = svalue
		                    checkParam.Value = bvalue
		                Else
		                    checkParam.Expression = sourceUserParam.Expression
	            Next
				Logger.Debug("Skipped file: " & partDoc.FullFileName)
			End Try
    Next
	If oSourceDoc IsNot Nothing Then
		If oSourceDoc.Views.Count=0 Then
			oSourceDoc.Close(True)
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 24 of 27
jnewon
Thanks to all the worked on this. It works great for me using inventor 2023.
I have one question, I noticed that if the parameter doesn't exist it adds the pushed parameters to all the parts. Is there a way to prevent this?
I'm working with a top level assembly. I have 3 different length parameters I want pushed (Length_1, Length_2, Length_3). Only curtain parts use Length_1 and have a matching parameter in that part. The code puts all pushed parameters in the parts used or not. This I don't need. Only to update the parameter that exists in the part.
John
Message 25 of 27
Ralf_Krieg
Hello
Comment this part of the code, that creates a non existing parameter. In this case, the "If checkParam Is Nothing Then" statement will just do nothing and process the next parameter.
Else
R. Krieg
RKW Solutions
Message 26 of 27
jnewon
Thanks for pointing that out. I totally missed that piece of code.
Message 27 of 27
johan
This code works perfectly!
So I made a template assembly with all parameters imported from an xml.
I pushed them forward to all underlying parts, works like a charm, so all userparameters in all assemblies and or parts are the same, and of course unique.
Now I made a form, where I change one parameter.
I created the event trigger on change parameter, but I can't seem to getting it to work to populate only that changed parameter to the below lying parts.
It's a tank, on which I want to change it's diameter, length etc, to be able to simulate afterwards.
What I would need:
On change parameter t_l
Run through all underlying parts and update t_l with that value.
thisassembly.document.update lets Inventor crash.
Calling the complete code (thus running over all of the parameters, gives an error) on parameterchange gives an error.
Pack&go attached Version 2024
