ilogic project part sketch into assembly sketch
snichols
snichols
I am trying to project a sketch from a part in an assembly to an assembly sketch. I have the below code started but get an undefined error, any help would be appreciated.
'Get the assembly component definition
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oMatrix As Matrix = oTG.CreateMatrix
Dim oOccurrence As ComponentOccurrence
Dim compOcc1 As ComponentOccurrence = oAsmCompDef.Occurrences.ItemByName("HANDHOLE RIM - J025938:1")
' Get the X-Y work plane.'Dim SketchPlane As Inventor.WorkPlane = compOcc1.WorkPlanes.Item(2)
Dim SketchPlane As WorkPlane
SketchPlane = compOcc1.Definition.WorkPlanes("XZ Plane")
'Create the proxy planes / points / axis
Dim oproxySketchPlane As WorkPlaneProxy = Nothing
compOcc1.CreateGeometryProxy(SketchPlane, oproxySketchPlane1)
' Create a new sketch.
Dim oSketch1 As Inventor.PlanarSketch
oSketch1 = oAsmCompDef.Sketches.Add(oproxySketchPlane1, False)
oSketch1.Name = "aCutout"
'Sketch.Edit()
'Get Part sketch
Dim oSketch2 As PlanarSketch = compOcc1.Definition.Sketches("CUTOUT")
Call oSketch2.CopyContentsTo(oSketch1)
WCrihfield
Also you added a 1 to the end of "oproxySketchPlane" when defining oSketch1.
Wesley Crihfield
(Not an Autodesk Employee)
