ilogic: problem to change material
michaelackermann1187
at first sorry for my bad English. I found an ilogic who is working very well but I have one problem:
It is changing my material in librarys too. I like to change code in this way that it changes only parts which are in the
folder of the iam. Maybe something with ThisDoc.PathAndFileName(False)?
Here is the Code I use:
For Each ComponentOccurrence In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
If iProperties.Value ("Custom", "Werkstoff") = "1.4301" Then
If iProperties.MaterialOfComponent (ComponentOccurrence.Name) = "St 37-2" Then
iProperties.MaterialOfComponent (ComponentOccurrence.Name) = "1.4301"
If iProperties.Value("Custom", "Werkstoff") = "St 37-2" Then
If iProperties.MaterialOfComponent (ComponentOccurrence.Name) = "1.4301" Then
iProperties.MaterialOfComponent(ComponentOccurrence.Name) = "St 37-2"
Next
Best Regards
Michael
rossano_praderi
Hi Michael,
if i understand your requirements you will solve your issue with something like this.
oDoc = ThisDoc.Document
aPath = ThisDoc.Path
For Each cOcc In oDoc.ComponentDefinition.Occurrences
oPath = Replace(cOcc.Definition.Document.File.FullFileName, _
					"\" & cOcc.Definition.Document.DisplayName, "")
If oPath = aPath Then
		If iProperties.MaterialOfComponent (cOcc.Name) = "St 37-2" Then
			iProperties.MaterialOfComponent (cOcc.Name) = "1.4301"
		If iProperties.MaterialOfComponent (cOcc.Name) = "1.4301" Then
			iProperties.MaterialOfComponent(cOcc.Name) = "St 37-2"
Next
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
