iLogic - Place specific part into specific hole
markoni.vts
markoni.vts
Hello there!
I am working with furniture.
For every product, I have 3D model assembly with sub-assemblies with a lot of holes.
I must place fittings (screws, dowels, eccentric connectors...) manually into every hole, from my fittings library.
But, I have some standard holes, with standard dimensions (example Ø15/10) where I place standard fitting (eccentric connector.ipt) for that hole.
  • Is there any solution where iLogic recognise all holes with dimensions Ø15/10 in assembly and sub-assemblies and automatically call and place fitting (eccentric connector.ipt) from library into every hole with mate constrain with bottom of the holes?
A.Acheson
Here is a starting point for you. It is working to find circular edges in the face selected.  I know in your case that edge may be deeper but that should me a minor modification to get that to work.  See if that works and post back with any question.
Sub Main
	Dim oAssyDoc As AssemblyDocument = ThisDoc.Document
	Dim oAssyDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
	Dim oFace As Face = ThisApplication.CommandManager.Pick _
									   (SelectionFilterEnum.kPartFaceFilter, _
									   "Select an occurrence with holes, Press Esc when Complete")
    If oFace Is Nothing Then Exit Sub 'User canceled so Exit Out
	Dim oOcc1 As ComponentOccurrence = oFace.Parent.Parent
	Dim i As Integer = 0 'Start Index for edge naming
	For Each oEdge As Edge In oFace.Edges
		i = i + 1
		HighlightEntities(oOcc1, oEdge, i) 'Use tool to identify edges
		If oEdge.GeometryType = CurveTypeEnum.kCircleCurve Then 'Check it is a circle so likely a hole
			Dim oCircle As Circle = oEdge.Geometry 'Get a Hole selection from the user
			Dim Hole_Dia As Double = Round(((oCircle.Radius * 2)* 10), 2)'Converted to Diameter and mm'
			If Hole_Dia = 10 mm Then
	            Dim oScrew  = Components.AddContentCenterPart("","Fasteners:Bolts:Countersunk","DIN 7991", "M8x60")
				Dim oOccScrew As ComponentOccurrence = oScrew.Occurrence
				Dim ScrewDef As PartComponentDefinition = oOccScrew.Definition
				Dim oEdge1 As Edge = ScrewDef.SurfaceBodies.Item(1).Edges(3)'Select Specific edge of screw
				'HighlightEntities(oOccScrew, oEdge1, i)'Use tool to identify edges
				Dim oEdgeProxy1 As EdgeProxy 'Create a proxy edge
				Call oOccScrew.CreateGeometryProxy(oEdge1, oEdgeProxy1)
				Dim oEdgeProxy As EdgeProxy ' Circle Edge Proxy of the part
				Call oOcc1.CreateGeometryProxy(oEdge, oEdgeProxy)
				'Create the insert Constraint between the parts.
				Dim oInsert As InsertConstraint = oAssyDef.Constraints.AddInsertConstraint _
												  (oEdgeProxy1, oEdgeProxy, False, -3 / 10)
	Next
End Sub
Sub HighlightEntities(oOcc As ComponentOccurrence,obj As Object,i As Integer)
	Dim oDoc As Document = ThisDoc.Document
    Dim objProxy As Object
	oOcc.CreateGeometryProxy(obj, objProxy)
	Dim oSet1 As HighlightSet = oDoc.CreateHighlightSet 'Create a highlight Set.
	Dim oSet2 As HighlightSet = oDoc.CreateHighlightSet 'Create a highlight Set.
	If Not obj.GeometryType = CurveTypeEnum.kCircleCurve Then 'Check it is a circle so likely a hole
		oSet1.AddItem(objProxy) 'Add the first face to the highlight set.
		oSet1.Color = ThisApplication.TransientObjects.CreateColor(230, 31, 31) 'Change the color of the highlight set to green.
	Else
		oSet2.AddItem(objProxy)' Add the first face to the highlight set.
		oSet2.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0) 'Change the color of the highlight set to green.
	ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Object Check:" & i & ". Press Esc to Move to Next Object")
	'[Pause Inventor between selections'alternative is use a message box
	'https://ekinssolutions.com/selecting-multiple-entities-using-pick-in-inventor/
	System.Windows.Forms.Application.DoEvents()
    System.Threading.Thread.Sleep(200)
End Sub
Regards
Alan
