ilogic pdf rule
ilogic pdf rule
ilogic pdf rule
Hi all,
At the moment i am looking for a solution to save pdf files from the idw files with a ilogic rule.
This rule, as shown, is used at the moment but I just want to add the title of the .idw
the pdf doc name will appear MET-DWG-"FILENAMEDOC"-REV-"SUMMARYTITLE".PDF
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\")) & "TEMPORAIRE"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\MET-DWG-" & oFileName &
" -REV" & oRevNum & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Ktomberlin
Try that, you need to grab the Title, then add it to your Filename.
dwgTitle = oDocument.PropertySets.Item("Summary Information").Item("Title").Value
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
" -REV" & oRevNum & "-" & dwgTitle &".pdf"
'Publish document
this is the final rule we use. We change the summary title to custom title.
SyntaxEditor Code Snippet
oDocName = iProperties.Value("Custom", "TITLE")
 If oRevNum = String.empty Then
"-00" & oRevNum & "-" & oDocName & ".pdf"
Else
"-" & oRevNum & "-" & oDocName & ".pdf"
'Publish document
