iLogic - Pattern occurrence w/out features
Hello
I want to pattern all parts but i don't want to take component feature (see picture below)
the number at the end of each part can be change.
i have this part of code, but it give an error message if i have pattern element.
oOccurrence = oAsmCompDef.Occurrences.Item(1)
oParentOccs.Clear
For Each oOccurrence In oAsmCompDef.Occurrences
    oParentOccs.Add(oOccurrence)
Next
oRectOccPattern = oAsmCompDef.OccurrencePatterns.AddRectangularPattern _
(oParentOccs, oYAxis, True, 2*oRowSpacing*2.54, oRowCount/2+0.5)
tanks for your help.
I had an idea,
if I suppress the component pattern, it is possoble to pattern all parts without take the suppressed parts.
I had try it and i take this error:
Error in rule: Dimension de la barge, in document: Test iLogic assemblage caisson BOC.iam
Paramètre incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
System.ArgumentException: Paramètre incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OccurrencePatterns.AddRectangularPattern(ObjectCollection ParentComponents, Object ColumnEntity, Boolean ColumnEntityNaturalDirection, Object ColumnOffset, Object ColumnCount, Object RowEntity, Boolean RowEntityNaturalDirection, Object RowOffset, Object RowCount)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Ok, i found imself the solution,
here my part of code:
oParentOccs.Clear
For Each oOccurrenceNotPattern In oAsmCompDef.Occurrences
If Component.IsActive( oOccurrenceNotPattern.Name) Then
'For Each oOccurrence In oAsmCompDef.Occurrences
If Not TypeOf oOccurrenceNotPattern.Definition Is VirtualComponentDefinition Then
	oParentOccs.Add(oOccurrenceNotPattern)
Next
(oParentOccs, oYAxis, True, 2*oRowSpacing*2.54, oRowCount/2-0.5)
