Ilogic parameters
Ilogic parameters
bronc3buster842001
Ilogic parameters
bronc3buster842001
How do I use parameters in this code to save as file name. DIAXLENGTH needs to be the value in the parameters. So say 5x11
NewFileName = ThisDoc.Path & "\" & "DIAxLENGTH.ipt"
ThisDoc.Document.SaveAs(NewFileName,True)
Ralf_Krieg
Hello
If the parameter names are DIA and LENGTH then
NewFileName = ThisDoc.Path & "\" & DIA & "x" & LENGTH & ".ipt"
R. Krieg
RKW Solutions
www.rkw-solutions.com
bronc3buster842001
Thank you. Works perfect.
A.Acheson
And to add to the code by @Ralf_Krieg  which would be for an internal rule, the below are for external rules where you have to refer to the parameter using parameter snippet found here.
NewFileName = ThisDoc.Path & "\" & Parameter("DIA") & "x" & Parameter("LENGTH") & ".ipt"
MessageBox.Show(NewFileName, "Title")
Or by using variables declared as string you can reuse the parameters and can make it easier to read,navigate and update.
Dim oDia,oLength As String
oDia = Parameter("DIA")
oLength = Parameter("LENGTH")
NewFileName = ThisDoc.Path & "\" & oDia & "x" & oLength & ".ipt"
Regards
Alan
