iLogic - open part and save it
JoãoASilva
Message 1 of 14
JoãoASilva
Hello
Two days ago I posted in this forum asking about saving a copy of a part from a drawing: https://forums.autodesk.com/t5/inventor-forum/save-copy-of-part-from-drawing/m-p/8230281#M709864
In that post, I was refering to a VBA code.
In the meantime, after doing a lot research, I still can't find nothing helpful.
I'd like to try to use iLogic do accomplish my goal, wich is:
- Have a drawing opened;
- Run rule (wich does the following):
     - Save copy of drawing  as .pdf (already found how this one is done);
     - Open the part associated to the drawing (they share the same name and folder ; found how it is done as well);
     - Save copy of part as .step (I have a rule in part to do so);
     - Close part.
iLogic Rule
Dim oPart As Document
Dim oPartPath As String
' Get drawing path
oPartPath = ThisDoc.PathAndFileName(False) & ".ipt"
' Open Part
oPart = ThisDoc.Launch(oPartPath)
From now on, the problem is to set the opened part as active(?), so I can run rules that are in the opened part.
I'm fairly amateur when it comes to coding, but I try to understand every line of code.
Thanks in advance,
João
João Silva
Mechanical Engineer
Replies (13)
Message 2 of 14
CCarreiras
You cant close a file from a own rule. If you want to close the part, you have to do it from other file.
Why not have all the rules in the drawing?
CCarreiras
Message 3 of 14
tdant
Replace the last line of your code with this block.
' Set a reference to the target part
oPart = ThisApplication.Documents.ItemByName(oPartPath)
' Open the target part
ThisDoc.Launch(oPart)
' Save a copy of oPart as a step file
oPart.SaveAs(Replace(oPartPath, ".ipt", ".step"), True)
' Close oPart
oPart.Close
The rule that saves the part doesn't have to be inside the part itself. You can still save it from a rule in another document, which is what this does.
Message 4 of 14
JoãoASilva
Didn't knew that.
Well, I can have all the rules in the drawings, no problem, I just want it to work. Smiley Very Happy
João Silva
Mechanical Engineer
Message 5 of 14
JoãoASilva
' Get drawing path
' Close oPart
oPart.Close
And I'm getting an error:
Any ideas?
João Silva
Mechanical Engineer
Message 6 of 14
CCarreiras
Hi!
Times ago, I did something like this:
In assembly:
Go to every Assembly file
The ones which are Sheet Metal, export dxf
The ones which are parts save as step
Why do you need to do that from the drawing?
Só por curiosidade...
CCarreiras
Message 7 of 14
JoãoASilva
Because the drawing is the last step before production, and we need to send the parts and drawings in various file formats, depending on the production method.
With that in mind, if i had rules for the differents production methods, I could just hit one button (macro to run rule) and it would save the files according to the production method.
João Silva
Mechanical Engineer
Message 8 of 14
CCarreiras
OK... i prefer to do all from the Assembly file. I think is easier to track files from the file than use other to fire rules... you have to catch all info, etc. If you use the assembly, the assembly will be the active doc.
I guess in every method there's always pros and cons.
CCarreiras
Message 9 of 14
JoãoASilva
Easier to track, it's true.
But since we have this workflow, and we manually do the drawing for production, it's simpler for us this way.
João Silva
Mechanical Engineer
Message 10 of 14
tdant
Sorry about that, my iLogic is a little rusty. Here's the correct, tested rule that will fit the bill:
Dim oPart As PartDocument
' Get drawing path
ThisApplication.Documents.Open(oPartPath)
' Close oPart
oPart.Close
Message 11 of 14
JoãoASilva
That's great, you solved it 😉
My next step is to get everything to work with vba, so I can export multi-sheets with revision, among others.
Kudos to you sir.
João Silva
Mechanical Engineer
Message 12 of 14
tdant
Happy to help. If you get hung up with the VBA, give me a shout.
Message 13 of 14
Thank you for your availability, I really appreciate it. Smiley Happy
Message 14 of 14
JoãoASilva
I used another account to reply, my bad.
João Silva
Mechanical Engineer
