iLogic - On top level Assembly refresh position of part in flexible Subassembly
Hello everyone,
I‘m looking for some solution for easier and faster work. Maybe have a someone some idea if is possible to refresh the position of part in flexible subassembly if I drive them on top Assembly?
In this case I need to have the same position of part on top Assembly and Subassembly.
I added a video for easier understanding what I looking for.
Thank you very much for any help.
With kind regards,
Jernej Puc
A.Acheson
"The flexible state for each instance is stored only in the consuming assembly, not in the individual components."
I take this as the Main assembly where the flexibility is used is the only place you can see the correct position. This reflects in what I have tested and your video.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
If you use adaptive you can drive the change from the top down and it will update in the sub assembly. In the sub assembly the constraint is still free to move , so if you move the part it will look to the top assembly and drive the constrained again to correct the location (Update).
Another option is to  constrain in the sub assembly and then drive the constraint via iLogic from the top. This has the disadvantage in that you need to measure where your equipment is.
Regards
Alan
Dear @A.Acheson,
Thank you very much for your reply and this explanation. This solution with adaptive Subassembly is in this case the best way for me.
Thank you a lot for your help!
With kind regards,
Jernej
