iLogic oFactory.DefaultRow > Activate next row in table
AntónioMC
AntónioMC
Hi
I'm trying to create an iLogic that just activates the next/previous table row in current iPart or iAssembly. Nothing else.
I am unable to do the basics.
This is my current iLogic code.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oFactory As iPartFactory = oDef.iPartFactory
oFactory.DefaultRow = oFactory.DefaultRow.Index + 1
iLogicVb.UpdateWhenDone = True
Any help?
theo.bot
You have to define the row in your code, you where almost there :-).
Dim
oDoc As PartDocument = ThisDoc.Document Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition Dim oFactory As iPartFactory = oDef.iPartFactory Dim oRow As iPartTableRow If oDef.IsiPartFactory Then oRow = oFactory.TableRows.Item(oFactory.DefaultRow.Index+1) oFactory.DefaultRow = oRow End If
AntónioMC
Thank you. Worked perfect!
What I wanted to do was to create a shortcut to cycle in the iPart table.
Here is a screencast of it working: https://autode.sk/30kkegZ
This is the code I have. Any tip to improve the code?
'iPart Select Previous
Dim oDoc = ThisDoc.Document
If oDoc.DocumentType = 12290 'kPartDocument
	If oFactory.DefaultRow.Index = 1 Then Return
		oRow = oFactory.TableRows.Item(oFactory.DefaultRow.Index - 1)
If oDoc.DocumentType = 12291 'kAssemblyDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oFactory As iAssemblyFactory = oDef.iAssemblyFactory
	Dim oRow As iAssemblyTableRow
	If oDef.IsiAssemblyFactory  Then
'iPart Select Next
	If oFactory.DefaultRow.Index = oFactory.TableRows.Count Then Return
		oRow = oFactory.TableRows.Item(oFactory.DefaultRow.Index + 1)
