ilogic name of featurs holes in idw
omvcilindri
omvcilindri
I have a question about laying out, I create my part with example N ° 10 holes in various positions that intersect each other, if I rename all the featurs holes, it is possible to report the name of featurs holes on the drawing in some way?
WCrihfield
It's a little difficult to fully understand the situation and the question.  Can you provide more details, sample file, or list of steps you want to happen?  It sounds like your example is a part document, in which you have a solid model that you have created 10 separate hole features into, and each of these hole features intersect each other at some point as they pass through the solid model?  And you have given each one of these hole features a unique name?  And now you want to be able to call out each one of the holes on the drawing by its feature name, correct?
Wesley Crihfield
(Not an Autodesk Employee)
omvcilindri
sorry my english is not very good,
I try to explain with screen shots.
I would like to report the name of the holes feature on the drawing with a text leader in automatic whit ilogic.
