iLogic LOD and the Vault .dwf visualisation
We use iLogic template assemblies to design our systems. These work by resizing and suppressing parts within them depending on the configuration required. The problem comes when the project mangers, who can only access the .dwf visualisation files in the Vault, try to check them.
As the vault saves the .dwf file from the 'Master' level of detail (LOD) which is incorrect, as opposed to the 'iLogic' LOD which is correct. The project managers cannot open the .iam files as they only have Vault Office and do not have Inventor on their machines.
Is there a way of changing the settings, within the vault/job processor, so that the 'iLogic' LOD is selected for creating .dwf visualisation files instead? or is it bad practice to use the 'iLogic' LOD to control the configuration?
I have tried creating a rule to change the LOD to 'iLogic' on opening and saving the document, but this has not worked. Please help! or my next job is creating a rule in each part to suppress all the features within when it is not required.
Thanks in advance.
Regards
Jason
