iLogic Issues
iLogic Issues
iLogic Issues
Good Morning all,
We are currently trying to update all our systems from Inventor 2018 to 2021 and I am having some issues with a Rule not running properly. When we start a new job, we are prompted to input all of the customer info when opening the assembly (this rule still works) then there is an iTrigger that auto populates the info into the tag on the base in the assembly. We also have a rule that populates the same info into the 2-d drawings which is working. I'm not sure if it's the iTrigger causing the problem, but it says it works when hitting it (the message box at the end of the code) when in fact it isn't. Are there any known issues with Rules/iTriggers? I've attached the rule below if that helps. Thanks in advance for any help!
mdavis22569
Likely need to share the code itself to the ticket for testing.   Kind of hard to help with a blurry image of coding.
Mike Davis
trigger = iTrigger0
' Get the active assembly document.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
'Global Values set
Dim CustomerCityName = iProperties.Value("Custom", "Customer City Address")
Dim CustomerName = iProperties.Value("Custom", "Customer Name")
Dim CustomerPart = iProperties.Value("Custom", "Customer Part Number")
Dim CustomerStreet = iProperties.Value("Custom", "Customer Street Address")
Dim WorkOrder = iProperties.Value("Custom", "Work Order #")
Dim Gage = iProperties.Value("Custom", "Gage Number")
Dim RevLevel = iProperties.Value("Custom", "Rev. Level")
' Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' Verify that the document is a part.
    If oDoc.DocumentType = kPartDocumentObject Then
        Dim oPartDoc As PartDocument = oDoc
'Manipulate part
        Dim model As String = oPartDoc.DisplayName
        model = model & ".ipt"
        Try
            If iProperties.Value(model,"Summary", "Category") = "Custom" Then
                Else
				'Sets Custom Properties for Components that are in the Main Assembly.
				iProperties.Value(model,"Custom" , "Customer City Address") = CustomerCityName
				iProperties.Value(model,"Custom" , "Customer Name") = CustomerName
				iProperties.Value(model,"Custom" , "Customer Part Number") = CustomerPart
				iProperties.Value(model,"Custom" , "Customer Street Address") = CustomerStreet
				iProperties.Value(model,"Custom" , "Work Order #") = WorkOrder
				iProperties.Value(model, "Custom", "Gage Number") = Gage
				iProperties.Value(model,"Custom" , "Rev. Level") = RevLevel
        Catch
		End Try
Next
MessageBox.Show("Gage Tag information is updated", "Gage Tag Update")
Sorry about that, thanks!
marcin_otręba
Try to reset your display name first :
oPartDoc.DisplayName=""
and check if it already does not contains ipt in it:
		If Right(model,4)<> ".ipt" Then
trigger = iTrigger0
'Global Values set
Dim CustomerCityName = iProperties.Value("Custom", "s_length")
Dim CustomerName = iProperties.Value("Custom", "s_width")
Dim CustomerPart = iProperties.Value("Custom", "laser")
Dim CustomerStreet = iProperties.Value("Custom", "description_pl")
Dim WorkOrder = iProperties.Value("Custom", "stock")
Dim Gage = iProperties.Value("Custom", "spot")
Dim RevLevel = iProperties.Value("Custom", "cutting")
'Manipulate part
Try
	Catch
	End Try
        Try
                Else
        Catch
		End Try
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
