iLogic isn't waiting for DrawingBaseViewCmd to finish running
matt_jlt
Message 1 of 13
matt_jlt
I have an issue where the ilogic script isn't waiting for the view place command to complete before it continues if i try to do anything after running the script. For example, if it's right before the end of the sub it works file. If there is code doing something after it it closes.
So looking at the below snippet, if i ran it twice, it would just flash up for a split second and skip then run the second one like normal. I have tried the other options such as ".Execute" & ".Execute2(True)" but they both just place the view automatically without the user getting to interface with the view place / edit dialog.
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, strFilename)
ThisApplication.CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd").Execute2(False)
I have tried putting it in a loop so for each filename in a list it is meant to run the view place command, wait for user to select then continue to the next one. it just skips to the last one and doesn't wait for the user.
Does anyone have any ideas because i can't work it out.
Thanks, Matt.
Currently testing it on Inventor 2019 / iLogic.
Replies (12)
Message 2 of 13
A.Acheson
@matt_jlt
Is the manual placing of the view part of the view place command routine? If you run the command on its own will it put the view on the end of the cursor?
I came across this skipping the user input scenario  when using a select occurance code.
I solved it elegantly? By placing a self cancelling message box which was enough to stop and allow the user pick up the occurances.
https://forums.autodesk.com/autodesk/attachments/autodesk/120/118325/2/T%26P_%20Run%20Constraint%20M...
Can you try it with just a message box does it allow the user to finish the view placement.
Regards
Alan
Message 3 of 13
matt_jlt
Hi Alan, thanks for your sugestion but it didn't seem to work.
Thanks, Matt.
Message 4 of 13
matt_jlt
Just to clarify, If i change the code to "Execute(True)" and it is run  on a button click and no form closing events are triggered, it waits for the code to finish. But if it is triggered after a form closing event which is what i actually wanted, If just places the view on the sheet with no user input and continues.
Seems like a weird bug maybe tied to events?
Message 5 of 13
moveworkforward
Hi @matt_jlt ,
maybe this will help you. I have an AddIn (written in VB) with multiple extra functions I need. When developing I faced a similar issue. I had to implement an automatic centerlines placing to each new view added. So I resolved the problem by running the Sub AddCenterLines (see the code snippets) in the new thread. See the lines:
Dim thread As New Thread(AddressOf AddCenteLines)
thread.Start()
 Note that  in  AddCenterLines I check for the view to finish an update:
Do While oView.IsUpdateComplete = False
g_inventorApplication.UserInterfaceManager.DoEvents()
Loop
So the full two subs are:
Private Sub DrawingUserInputEvents_OnTerminateCommand(CommandName As String, Context As NameValueMap) Handles DrawingUserInputEvents.OnTerminateCommand
    Try
        If CommandName = "DrawingBaseViewCmd" Or CommandName = "DrawingProjectedViewCmd" _
        Or CommandName = "DrawingSectionViewCmd" Or CommandName = "DrawingDetailViewCmd" _
        Or CommandName = "DrawingAuxiliaryViewCmd" Or CommandName = "DrawingBreakOutViewCmd" Then
            Dim oDrawDoc As DrawingDocument = g_inventorApplication.ActiveDocument
            thread.Start()
    Catch
    End Try
End Sub
Private Sub AddCenteLines()
    Try
        Dim oSheet As Sheet = oDrawDoc.ActiveSheet
        Dim oView As DrawingView : oView = oSheet.DrawingViews.Item(oSheet.DrawingViews.Count)
        If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            If My.Settings.AssemblyCenterLines = False Then Exit Sub
        ElseIf oView.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kPartDocumentObject Then
            If My.Settings.PartCenterLines = False Then Exit Sub
        Else Exit Sub
        Loop
        Dim oCenterline As AutomatedCenterlineSettings = Nothing
        oView.GetAutomatedCenterlineSettings(oCenterline)
        oCenterline.ApplyToHoles = True
        oCenterline.ProjectionParallelAxis = True
        oView.SetAutomatedCenterlineSettings(oCenterline)
    Catch
    End Try
End Sub
 Probably there are better solutions to this problem but this one works for me.
Message 6 of 13
moveworkforward
This works in ilogic. Do While Loop pauses the further code execution until view is placed.
Dim strFilename As String = "Your part file full path"
If Dir(strFilename) <> "" Then
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oView As DrawingView = oSheet.DrawingViews.Item(oSheet.DrawingViews.Count)
	     Call  ThisApplication.UserInterfaceManager.DoEvents
	Loop
	Call oView.GetAutomatedCenterlineSettings(oCenterline)
	Call oView.SetAutomatedCenterlineSettings(oCenterline)
Else
	MessageBox.Show("Specified file does not exist.")
Message 7 of 13
matt_jlt
Thanks for your efforts, It does not seem to solve my problem. When i run your example ilogic code exactly as is but swapping out the filename, inventor automatically places the view in the bottom left hand corner of the sheet every time (I assume this is location 0,0 for the sheet coordinates).
I suspect that if it is working for you then the problem i am experiencing is more likely the version of inventor on the machine i am testing it on which is inventor 2019.
Can i ask if you are running inventor 2019 or the more recent versions 2020/2021.
Message 8 of 13
moveworkforward
Hi @matt_jlt
That piece of code does exactly what you said. My point was just to show how to pause an Ilogic code execution.
Anyway try the code below. I hope it helps solving your problem.
Please first fill out 3 full file names at the top of the code.
After you run it the ilogic waits for you to click somewhere at the drawing space to get the position for the new drawing view. Than it places the view and offers you to edit the view orientation and so on.  When you are done it repeats all these steps for other files in the list.
Public Class ThisRule
Public strFilename1 As String = "Add here your assembly or part file path"
Public strFilename2 As String = "Add here our assembly or part file path"
Public strFilename3 As String = "Add here your assembly or part file path"
Public oPosition As Point2d
Public oInteraction As InteractionEvents
Public oMouse As MouseEvents
Private mouseClicked As Boolean
Sub Main
	 oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
	 oMouse = oInteraction.MouseEvents
	 AddHandler oMouse.OnMouseClick  ,AddressOf oMouse_OnMouseDown
	Dim nameList() As String = {strFilename1,strFilename2,strFilename3}
	For i = 0 To nameList.Length - 1
		oInteraction.Start
		AddDrawingView(nameList(i))
	Next
End Sub
Sub AddDrawingView(name As String)
	Dim oDoc As Document = ThisApplication.Documents.Open(name, False)
	Do While mouseClicked = False
	Loop
	Dim Scale As Double = 1/2
	Call oDrawDoc.ActiveSheet.DrawingViews.AddBaseView(oDoc, oPosition, Scale, _
									ViewOrientationTypeEnum.kDefaultViewOrientation, _
						DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, , , )
	oDoc.Close
	Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
	Dim oControlDef As ControlDefinition
	Dim lastViewIndex As Integer = oDrawDoc.ActiveSheet.DrawingViews.Count
	oDrawDoc.SelectSet.Select(oDrawDoc.ActiveSheet.DrawingViews(lastViewIndex))
	oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingViewEditCtxCmd")
	oControlDef.Execute2(True)
	Dim oView As DrawingView = oDrawDoc.ActiveSheet.DrawingViews(oDrawDoc.ActiveSheet.DrawingViews.Count)
	Loop
	Call AddCenterLines(oView)
End Sub
Sub AddCenterLines(oView As DrawingView)
End Sub
 Sub oMouse_OnMouseDown(Button As MouseButtonEnum, ShiftKeys As ShiftStateEnum, _
 						ModelPosition As Point, ViewPosition As Point2d, View As Inventor.View)
  oPosition = ThisApplication.TransientGeometry.CreatePoint2d(ModelPosition.X, ModelPosition.Y)
  mouseClicked = True
End Sub
End Class
Message 9 of 13
matt_jlt
While i still have the same bug, Your last example is definitely a good workaround with the exception of the inability for the user to select sheet metal placement which is something i definitely need to have. I marked your answer as the solution as it seems like i will have to wait for the company i am working for to upgrade to a newer version without the bug.
I didn't even think of approaching it that way. And you inadvertently helped with with another problem i had with something else with implementing user interaction events.
I will implement your code into my example with a few tweaks. I really appreciate your help.
The main reason i am trying to do this all in ilogic is so i can share all my code / snippets with everyone on github once i tidy it all up a bit.
Thanks again.
Message 10 of 13
moveworkforward
I am not sure what you mean about the bug.. Does the the code I sent run smoothly for you? Because I use Inventor 2018 and it runs without problems...
As for the sheet metal issue. If I need to place a sheet metal flat pattern then I use an extra options for adding view:
Dim oBaseViewOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
			DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, , ,oBaseViewOptions )
Message 11 of 13
moveworkforward
Ok now see what you mean. You refer to the original PostPrivateEvent problem. In 2018 version I have the same issue.
Message 12 of 13
matt_jlt
Yeah, that's what i am referring to. I think i was having two issues. the initial bug as well as the not waiting for the view to update.
Thanks again.
Message 13 of 13
JMGunnar
Is there different if you check this options on/off ?
