ilogic iproperty inspection parts within assembly
the idea is to run the rule in an assembly.
the rule looks at each part and inspects the iproperties.
if an iproerty is found which doesn't conform to the required standard then it's changed.
what i can't do is cycle through the parts.
the inspiration behind this comes after the copy design of a frame within vault.
the part number is changed to xyz 00000000001 where I'd like to swap out the 0000000001 for the
length & cross section of the frame gen member.
I think I can swap the values, it's cycling from one part to the next which has me stumped.
MES
I show one way to iterate through all assembly documents in this post
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Ilogic-quot-Calculate-Square-Footage-q...
You would have to add a part document type filter if all you want are part documents under the assembly.
