iLogic/iProperty error
I setup a basic routine to generate custom iProperties for a file:
'Checks To see If the following iProperties exist and creates them if necessary
Dim FabProcess As String = "FABRICATION PROCESS"
Dim Inspect As String = "INSPECTION REQUIRED (Y/N)"
Dim merge As String = "MERGE"
Dim finish As String = "FINISH"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
prop = customPropertySet.Item(FabProcess)
prop = customPropertySet.Item(Inspect)
prop = customPropertySet.Item(merge)
' prop = customPropertySet.Item(finish)
Catch
' Assume error means not found
customPropertySet.Add("", FabProcess)
customPropertySet.Add("", Inspect)
customPropertySet.Add("", merge)
' customPropertySet.Add("", finish)
End Try
'output the custom iproperties and update the file
RuleParametersOutput()
InventorVb.DocumentUpdate()
Eveything runs fine until I un-comment the "finish" lines.
Any ideas?
frederic.vandenplas
You do a try catch over your entire block of code, so if one fails, all those behind will not be executed too.
Try catch should be avoided if you know that there is a possibility that something can/will go wrong (like there is no iprop
with that name)
If you do want to use it, put try catch around each iprop retrieve line
It's more neat to check if it's there and if not execute the code...
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
If customPropertySet.Item(FabProcess) Is Nothing Then
If customPropertySet.Item(Inspect) Is Nothing Then
If customPropertySet.Item(merge) Is Nothing Then
If customPropertySet.Item(finish) Is Nothing Then
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
wayne.brill
Hello S.McCarthy,
Can you mark this issue as solved (by Frederic) or reply with the current status? If you are getting errors please upload an Inventor file with the rule that is not working. (I am only seeing two posts on this issue).
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
b.mccarthy
Implementing the code supplied by Frederic generates an error. I can get the code to work using Try/Catch, but only for 3 fields. Adding a 4th causes the routine to fail, even if I reorder the code.
This is the current code:
'Try
'          prop = customPropertySet.Item(FabProcess)
'          prop = customPropertySet.Item(Inspect)
''          prop = customPropertySet.Item(merge)
'Catch
'      ' Assume error means not found
'          customPropertySet.Add("", FabProcess)
'          customPropertySet.Add("", Inspect)
''          customPropertySet.Add("", merge)
'End Try
I ran this code in a new part, assembly and drawing, and it fails everytime, regardless of which section of code is active.Any ideas?
wayne.brill
I find that error checking needs to be used when trying to get a property that may or may not exist.  (there is not a method like PropertySets.PropertySetExists for a Property) You can see this approach using error checking in the UpdateVolume() VBA example in the Inventor programming help. VBA uses Err for this. In VB.NET you would use Try Catch for similar functionality.
Here is the iLogic rule that works in my tests. The first time I run it in a new file the Properties are added with no values. The second time values are added to each property.
Dim myProp As Inventor.Property
Try
	myProp = customPropertySet.Item(FabProcess)
	myProp.Value = "WB_FabProcess"
Catch
	myProp = customPropertySet.Add("", FabProcess)
End Try
Try
	myProp = customPropertySet.Item(Inspect)
	myProp.Value = "WB_InSpect"
Catch
	myProp = customPropertySet.Add("", Inspect)
End Try
Try
  myProp = customPropertySet.Item(merge)
  myProp.Value = "WB_Merge"
Catch
	myProp = customPropertySet.Add("", merge)
End Try
Try
	myProp = customPropertySet.Item(finish)
	myProp.Value = "WB_finish"
Catch
	myProp = customPropertySet.Add("", finish)
End Try
Wayne
Wayne Brill
b.mccarthy
Works great!
Thank you!
